Has anyone got this up and running with the Zwave 2 module as it is seen by HA but I get this on importing the info for the module:
So HS sees it, it just seems not to know what it is.
I'm using the Z Tool to import it to a Z Net.
Any ideas on how to get HS to see it correctly would be appreciated.
K.
Aug-30 6:12:48 PM | Z-Wave Warning | Instant status and sensor wake-up notifications are not being programmed because HomeSeer is being used as an installation tool only. |
Aug-30 6:12:45 PM | Z-Wave | Node 61 is a Z-Wave Plus node. Retrieving ZWPlus Info... |
Aug-30 6:12:45 PM | Z-Wave | Node: 61 Supports Class(es): ZWAVEPLUS_INFO, TRANSPORT_SERVICE, SECURITY, SECURITY_2 |
Aug-30 6:12:45 PM | Z-Wave Warning | Node 61 does not support the manufacturer specific command class - it is either a really old device or there was a communications problem. |
Aug-30 6:12:45 PM | Z-Wave Warning | If this is an import, you may need to remove and add the device as some devices cannot be added with an import. |
Aug-30 6:12:45 PM | Z-Wave Warning | Failed to get a SECURITY SCHEME or verify the key from node 61. Device may not be added properly to HomeSeer. |
Aug-30 6:12:45 PM | Z-Wave Error | Z-Wave was unable to negotiate a compatible security scheme with node 61 |
K.
