I have been looking all morning here on the Forum but couldn't find what I needed.
Is there a way to poll all devices on startup? if so will battery devices be polled?
The reason for this is when HS3 is down for any reason and a device changes state and when HS3 restarts the status icon for that device is wrong. Once the device is used then it's back in sync with HS3. Example: hall light is off then HS3 goes down. Someone turns on the hall light using the switch. HS3 restarts but shows the light is still off. Once someone uses the light switch again then it's in sync.
Jim
Jim
