I've been working with a Z-Uno device and am having difficulty adding a sketch that includes two channels (single channel works fine). Both channels are multi-sensor distance sensors. HS seems to "see" both channels and shows two endpoints. I am able to include the device but it only creates a single child and reports both distance readings on the same child device. When I attempt a re-scan the log data below is included.
I found a similar issue reported last year on the z-uno forum and it references a fix instituted by HS. I am on the current BETA Z-Wave plugin (3.0.1.238). I can confirm that the z-uno sketch is correct as I get the proper output on a serial monitor from the device itself.
Sep-28 9:56:48 PM | Z-Wave | 1 out of 2 Child devices of node 109 were created successfully. |
Sep-28 9:56:47 PM | Z-Wave | Getting association information for Node 109 Z-Wave Z-Wave.Me Multilevel Sensor |
Sep-28 9:56:44 PM | HSBuddy | Cleanup thread removed 38 entries from device history. |
Sep-28 9:56:41 PM | Z-Wave | Assigning return route from node 1 to Node 109 Z-Wave Z-Wave.Me Multilevel Sensor |
Sep-28 9:56:41 PM | Z-Wave | SmartStick+: Adding association for Z-Wave device Node 109 Z-Wave Z-Wave.Me Multilevel Sensor (Node 109, Group 2, Endpoint 2) to HomeSeer |
Sep-28 9:56:34 PM | Z-Wave | Assigning return route from node 1 to Node 109 Z-Wave Z-Wave.Me Multilevel Sensor |
Sep-28 9:56:33 PM | Z-Wave | SmartStick+: Adding association for Z-Wave device Node 109 Z-Wave Z-Wave.Me Multilevel Sensor (Node 109, Group 1, Endpoint 1) to HomeSeer |
Sep-28 9:56:33 PM | Z-Wave | All associations for node 109 have been retrieved successfully, it supports associations on these groups: 1, 2. |
Sep-28 9:56:33 PM | Z-Wave | Node 109 Association Group 2 can have 8 associations, and currently has 1 |
Sep-28 9:56:33 PM | Z-Wave | Node 109 Association Group 1 can have 8 associations, and currently has 1 |
Sep-28 9:56:33 PM | Z-Wave | Getting association information for node 109 |
Sep-28 9:56:00 PM | Z-Wave | Processing Information for Node 109 Multi-CHANNEL Command Class of SENSOR_MULTILEVEL_V7, Endpoint 1 |
Sep-28 9:56:03 PM | Z-Wave Error | Failed to get the supported scale for sensor type Distance of new child device for node 109. Error C |
Sep-28 9:56:00 PM | Z-Wave | Processing Information for Node 109 Multi-CHANNEL Command Class of SENSOR_MULTILEVEL_V7, Endpoint 2 |
Sep-28 9:56:00 PM | Z-Wave Error | Exception creating Sensor Multilevel child device of node 109, GET for supported sensor types indicated failure. |
Sep-28 9:55:59 PM | Z-Wave | Node 109 is a Z-Wave Plus node. Retrieving ZWPlus Info... |
Sep-28 9:55:59 PM | Z-Wave | Node 109 is Z-Wave version: Lib: 4.38 App: 2.14 |
Sep-28 9:55:59 PM | Z-Wave | Node: 109 Controls Class(es): BASIC_V2 |
Sep-28 9:55:59 PM | Z-Wave | Node: 109 Supports Class(es): ZWAVEPLUS_INFO, BASIC_V2, CONFIGURATION_V4, ASSOCIATION_V2, MULTI_CHANNEL_ASSOCIATION_V3, FIRMWARE_UPDATE_MD_V2, DEVICE_RESET_LOCALLY, ASSOCIATION_GRP_INFO_V2, POWERLEVEL, VERSION_V2, MANUFACTURER_SPECIFIC_V2, SENSOR_MULTILEVEL_V7, MULTI_CHANNEL_V3 |
Sep-28 9:55:59 PM | Z-Wave | Syncing Z-Wave nodes with device list... |
