Hi,
I have added a Z-Wave.me UZB interface and am trying to add an Aeotec Multisensor 6 as a node. When I try "Add/Include a Node" I get the error below
The system log shows that it is unable to find the COM port /dev/ttyACM0
Can someone please point me in the right direction?
Oct-24 5:25:38 PM Z-Wave Warning Z-Wave.me: Cannot configure COM port /dev/ttyACM0, port does not exist in system, waiting then retrying...
Oct-24 5:25:37 PM Z-Wave Warning Z-Wave.me: Cannot configure COM port /dev/ttyACM0, port does not exist in system, waiting then retrying...
Oct-24 5:25:36 PM Z-Wave Warning Z-Wave.me: Cannot configure COM port /dev/ttyACM0, port does not exist in system, waiting then retrying...
Oct-24 5:25:35 PM Z-Wave Warning Z-Wave.me: Cannot configure COM port /dev/ttyACM0, port does not exist in system, waiting then retrying...
Oct-24 5:25:34 PM Z-Wave Warning Z-Wave.me: Cannot configure COM port /dev/ttyACM0, port does not exist in system, waiting then retrying...
Oct-24 5:25:34 PM Z-Wave Warning Z-Wave.me: Exception(1) with COM port (/dev/ttyACM0): Input/output error
Oct-24 5:25:31 PM Z-Wave Warning A Z-Wave interface on the system is being restarted - some Z-Wave signals could be missed.
Oct-24 5:22:35 PM Z-Wave Starting Z-Wave Polling for Network F7635D86...
Oct-24 5:22:18 PM Web Server Web Server authorized local login successful from: 192.168.1.112 User: default
Oct-24 5:22:09 PM Z-Wave ************************************************************ *******************
Oct-24 5:22:09 PM Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
Oct-24 5:22:08 PM Z-Wave Security S2 Support Is Enabled
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: ............................................................ ..........
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: .............................. FINISHED ..............................
Oct-24 5:22:08 PM Z-Wave Z-Wave.me is the SIS for the network.
Oct-24 5:22:08 PM Z-Wave Z-Wave.me There is a SUC/SIS in the network.
Oct-24 5:22:08 PM Z-Wave Z-Wave.me Controller is static lib.
Oct-24 5:22:08 PM Z-Wave Z-Wave.me Controller chip type is ZW050x.
Oct-24 5:22:08 PM Z-Wave The interface's security support has been set.
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: Found 1 Z-Wave nodes in interface node ID 1 (Z-Wave.me)
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: Z-Wave interface node ID: 1, Home ID: F7635D86
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: Z-Wave Serial API version: 5
Oct-24 5:22:08 PM Z-Wave Z-Wave.me: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
Oct-24 5:22:07 PM Z-Wave Z-Wave.me: Controller firmware version: 5.2
Oct-24 5:22:07 PM Z-Wave Z-Wave.me: Controller Manufacturer: PowerLynx, ID=0x1, Type=0x4
Oct-24 5:22:07 PM Startup Start up complete.
Oct-24 5:22:07 PM Info System connected to MyHS Service successfully with license ID 119329.
Oct-24 5:22:07 PM Info Latest BETA update available is: 3.0.0.478
Oct-24 5:22:07 PM Info Latest update available is: 3.0.0.475
Oct-24 5:22:07 PM Info System connected to MyHS Service, waiting for acknowledge...
Oct-24 5:22:07 PM TTS Speak ():Welcome to Home-Seer
Oct-24 5:22:07 PM Startup Scripting is OK and is now running Startup.vb
Oct-24 5:22:07 PM Info Checking for updates...
Oct-24 5:22:07 PM Startup HSSentry is disabled in Setup, sentry will not be started.
Oct-24 5:22:07 PM Startup Starting Event Scheduler...
Oct-24 5:22:05 PM Z-Wave Z-Wave.me: Getting node information from controller...
Oct-24 5:22:05 PM Z-Wave Z-Wave.me: The Z-Wave API Execution Thread was Started or Restarted.
Oct-24 5:22:05 PM Z-Wave Z-Wave.me: The Z-Wave Command Execution Thread was Started or Restarted.
Oct-24 5:22:05 PM Z-Wave Z-Wave.me: ----------------------------------------------------------------------
Oct-24 5:22:05 PM Z-Wave Initializing Z-Wave interface Z-Wave.me (Z-Wave.me UZB) on /dev/ttyACM0
Oct-24 5:22:05 PM Z-Wave Z-Wave.me: ============================================================ ==========
Oct-24 5:22:05 PM Z-Wave 465 Simple AV Control Command Class Control Commands have been loaded successfully.
Oct-24 5:22:05 PM Z-Wave 0 event triggers were loaded from HomeSeer.
Oct-24 5:22:05 PM Z-Wave 0 event actions were loaded from HomeSeer.
Oct-24 5:22:05 PM Starting Plug-In Plugin Z-Wave started successfully in 2788 milliseconds
Oct-24 5:22:04 PM Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/Z-Wave/Z-Wave2.db
Oct-24 5:22:02 PM Z-Wave InitIO called, plug-in version 3.0.2.234 is being initialized...
Oct-24 5:22:02 PM Starting Plug-In Initializing plugin Z-Wave ...
Oct-24 5:22:02 PM Info Plugin Z-Wave has connected. IP:127.0.0.1:52686
