Upgrading a Z-Troller to a Aeotec Z-Stick Gen5, Good Idea?
  • #31
    I don't see any issues with it detecting clicks. That stick has the same firmware that our stick has, the firmware was supplied by Sigma, the manufacturers do not create their own firmware. So the only difference is the hardware.
    OK, Thanks. I received my new SmartStick+ yesterday. I'll do some additional testing and will take your routing suggestion as well. It may be a few days before I am able to test as the location that is having the problem is my sister's lake-house and not my main residence. Appreciate the reply.
    • #32
      Sorry , sent you the log file this time rjh
      • #33
        rjh, DoubleClick Problem solved. I re-optimized the routing including return routes and now the DoubleClicks work as expected. Even as obvious as the real problem was, I suspect I had overlooked updating the routing when I installed the last couple of switches as I was focused on the difference of the Zooz controller. My bad.
        Thanks for the assist.
        • #34
          jvm .
          Now that we both have redone our zwave network.
          The real deal is to know if it is possible to backup the network from the zooz. And then restore it to another controler?
          Did you ever tried this? I am a little scared to try it, so I wonder if you already test this?
          I think this is important, because if there is any issue with the zooz, we need to be able to restore to another controller easily.
          In the scenario that this does not work, I wonder if it would work on another zooz s2 stick?
          What is your take on this?
          thanks,
          Matth
          • #35
            This is my zwave info . Like you, I also got the z-wave LIB warning . And also this :
            Zwave: Controller Manufacturer: UNKNOWN
            pr-06 17:57:23 Z-Wave Zwave: .............................. FINISHED ..............................
            Apr-06 17:57:23 Z-Wave Zwave: ......................................................................
            Apr-06 17:57:23 Z-Wave Zwave is the SIS for the network.
            Apr-06 17:57:23 Z-Wave Zwave There is a SUC/SIS in the network.
            Apr-06 17:57:23 Z-Wave Zwave Controller is static lib.
            Apr-06 17:57:23 Z-Wave Zwave Controller chip type is ZW050x.
            Apr-06 17:57:23 Z-Wave Warning Zwave: Z-Wave PC Controller Library Version: Z-Wave 6.02 (Unknown)
            Apr-06 17:57:23 Z-Wave Zwave: Found 14 Z-Wave nodes in interface node ID 1 (Zwave)
            Apr-06 17:57:23 Z-Wave Zwave: Z-Wave interface node ID: 1, Home ID: xxxxxxx
            Apr-06 17:57:23 Z-Wave Zwave: Z-Wave Serial API version: 8
            Apr-06 17:57:23 Z-Wave Zwave: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
            Apr-06 17:57:23 Z-Wave Zwave: Controller firmware version: 2.1
            Apr-06 17:57:23 Z-Wave Zwave: Controller Manufacturer: UNKNOWN, ID=0x2, Type=0x5
            Apr-06 17:57:21 Plug-In Finished initializing plug-in Z-Wave
            Apr-06 17:57:21 Starting Plug-In Z-Wave loaded in 600 milliseconds
            Apr-06 17:57:21 Z-Wave Zwave: Getting node information from controller...
            Apr-06 17:57:21 Z-Wave Zwave: The Z-Wave API Execution Thread was Started or Restarted.
            Apr-06 17:57:21 Z-Wave Zwave: The Z-Wave Command Execution Thread was Started or Restarted.
            Apr-06 17:57:21 Z-Wave Zwave: ----------------------------------------------------------------------
            Apr-06 17:57:21 Z-Wave Initializing Z-Wave interface Zwave (HomeSeer SmartStick +) on /dev/ttyACM0
            Apr-06 17:57:21 Z-Wave Zwave: ======================================================================
            Apr-06 17:57:21 Starting Plug-In Plugin Z-Wave started successfully in 384 milliseconds
            Apr-06 17:57:21 Z-Wave 73 total Z-Wave Data Objects loaded.
            Apr-06 17:57:20 Z-Wave Loading Z-Wave Data Objects...
            Apr-06 17:57:20 Z-Wave 1 total Z-Wave Network Objects loaded.
            Apr-06 17:57:20 Z-Wave Loading Z-Wave Network Objects...
            Apr-06 17:57:20 Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database /HomeSeer/Data/Z-Wave/Z-Wave2.db
            Apr-06 17:57:20 Starting Plug-In Initializing plugin Z-Wave ...
            Apr-06 17:57:20 Info Plugin Z-Wave has connected. IP:127.0.0.1:38686
            Apr-06 17:56:59 Plug-In Found plug-in: Z-Wave, version: 3.0.1.260
            • #36
              The z-wave back up is done using info in the plugin, not the interface, so ANY network can be backed up. Its the restore that is to be programmed for the different interfaces.
              • #37
                That warning can be ignored, but its fixed in z-wave plugin 261.
                • #38
                  Yes , this is in line with what support said
                  Hello Matthieu,
                  The Zooz stick does not support restoring Z-Wave networks in HS3, only the SmartStick+ and US Z-Net interfaces do. I apologize for the inconvenience.
                  anyways i am returning this stick to Amazon. So, and I bought your new g2 stick as a replacement . It is good news that any network can be backup up . Thanks for the info
