Do you have problems or not, with Fibaro equipment not reporting W and kWh in HS?
  • Do you have problems or not, with Fibaro equipment not reporting W and kWh in HS?
    Have bought HS3 and are trying to move from Fibaro Homecenter 2 (HC2).
    The problem is that none of the Fibaro equipment I have, reports W or kWh in HomeSeer (without polling), tho it works without problems in HC2.
    What I try to do is to find out where the problem is.
    Do you have Fibaro equipment, and does it report W and/or kWh as it should?
    What verson of HomeSeer do you use?
    What type of transceiver do you use?
    What verson of the Z-Wave plug-in do you use?
    Thanks.
    I have a Fibaro dimmer and a rgb... all report W and kwh from inclusion without changing any polling settings. They have only been in my system for a few months though. But in general I have a lot of problems with power reporting with all sorts of manufacturers and different devices. Some devices have been reporting for years, others have stopped and are 'stuck' at a value, and never got them to report again.
    I have given up trying to 'repair' the devices which have stopped, I have wasted a lot of time trying to get it working again, with polling, rescans etc
      May I ask:
        Sorry I did not see your question until now. I am on HS3 .458, zwave .249 and I am using Z-net (v2 i think)
