Sensitive Strip Comfort
  • Sensitive Strip Comfort
    Click image for larger version  Name:	Capture.PNG Views:	3 Size:	45.1 KB ID:	1265363
    Has anyone had any success adding a Sensitive Strip Comfort (Temp and Lux) sensor. I tried 6 times trying to add this device next to my Znet controller with an error. See attached error.
    Have you tried this:
    https://sensativesupport.zendesk.com...Strips-Comfort
    Enabled Plug-Ins:
      Thanks for the reply. Finally I got this device included. It took about 2 min and I constantly swiped the magnet during the whole process to keep the device awake. I contacted support and they advised that the device only stays awake for 10 seconds. This is not normal when including a device but it works. Thanks for the tip.
        I have found them to be a bit flaky - especially the reported Lux values
          These devices are very hard to include.
            Ok so here's the way I got mine to include. Because the inclusion must occur rapidly before the device goes to sleep, it will not include in Z wave networks with more than a dozen devices or so. The more devices the longer inclusion takes.
            1- Backup of your z wave network in two copies.
            2- Edit one of the backups and remove all devices except Node 1. (your z wave stick)
            3- Restore from backup using the file with only Node 1.
            4- Include the Sensative Strip.
            5- Make another backup of your z wave network after a successful inclusion of the stick (LED should only blink once when you move the magnet to the round end indication proper pairing).
            6- Edit this new backup and copy the line for this new node (Assuming Node 2) and insert it in the original z wave backup file with all your other device.
            (You might need Node 2 to be free in your setup to do this. I have not tried changing the node number after pairing this way.)
            7- Restore this new modified backup.
            8- Go into Node 2 z wave setting. Wake up the strip with the magnet sequence then initiate rescan.
