When trying to buy Zwave dimmers, I can only find models in either white or almond. Aren't there any other colors available, like gray, brown or black? In particular, dimmers that work with LED lights. It would be nice to more options which fit in your room's design and color choice.
Dimmer switches in different colors
Leviton has the following color change kits: white, ivory, light almond, gray, black, and brown. See https://store.leviton.com/products/d...logy-dz1kd-1bz for one example.HS 4.2.8.0: 2134 Devices 1252 Events
Thanks, Sparkman. Is this one of the kits you are referring to: https://store.leviton.com/products/m...nt=19650904771 ?
Mural may be a specific line and not the same as the z-wave switches. I think these are the correct ones for the z-wave switches:https://store.leviton.com/products/d...ge-kit-ddkit-s and these for the dimmers: https://store.leviton.com/products/d...ange-kit-ddkit, but I would call or email Leviton to be 100% sure. I've found them to be responsive in the past.HS 4.2.8.0: 2134 Devices 1252 Events
I was able to pop the plastic faceplate off of my HS-WD100 and HS-WS100 dimmers / switches, take apart the plastic pieces, spray paint, and reassemble It was easy to do and came out well. Just paint using two very light coats - don't try to get perfect coverage all in one pass or you'll get runs in the paint.
- Likes 1
These fit the HS 200 series dimmers - probably the 100's as well.
https://www.zwaveproducts.com/shop/z...for-zwp-wd-100
Regards,
BBB
