Aeon Multisensor 6 Listening Mode
  • Aeon Multisensor 6 Listening Mode
    I have one multisensor 6 that shows the "listen" parameter as "no" in the node information (the rest all say yes) and displays this message on it's management screen:
    Error: The device Zfloor Z-Wave Aeon Labs Multilevel Sensor Grow Box is not a normally listening node, and an attempt to communicate with it has failed. To use the functions on this page, please make sure the device is awake and ready to receive a command prior to selecting the function buttons below.
    i understand that this is normal if the sensor is on battery power, but this one is not. I cannot find a way to reset this (rescan does not help) - I would really hate to have to remove it and add it in again as there are a lot of programs that use it. Would anyone know how to force this unit into listening mode?
    Temporarily applying USB power should put it in wakeup mode
      The sensor is permanently attached to USB power..... but homeseer seems to think it is on battery.....
        You probably need to exclude the device and reinclude it. Normally it should include as a listening node if it's added while on USB power, or as a non-listening node if added on battery power.
          I was hoping that wasn't the answer - but I fear that it is. I do faintly recall that this sensor may have been on battery when i first included it. Thanks.
