Lock suggestion for winter condition
  • Lock suggestion for winter condition
    Hi all
    Looking to change my front door locks
    But i live in canada so winter time can be difficult.
    Temperature goes to -40 celcius sometime.
    I was wondering if z wave lock can mange the fac that my door can work a little bit in winter. So the lock wont close fit 100%.
    As anyone experience that and what model you recommend.
    Thx
    Envoyé de mon Pixel 2 XL en utilisant Tapatalk
    Is it the lock hardware itself not turning? Or is the metal in the door contracting due to the cold? If it's the door then perhaps making adjustments to the door would help. If it's the lock then taking it apart and using lubricants designed for extreme cold might help.
      Its my door contracting
      And i'm looking for a model i don't know yet.
      Any suggestions ?
      Thx
        Oh, so you're looking for suggestions for a lock that will work in extended sub-zero conditions.
        But when your door contracts, does a normal lock still work smoothly?
          Yes its just my fear that what i do if the lock jam and im not at home and i thought it was lovk properly that why
            I’m in Calgary so not -40 very often, but we have had -30 a few times in the last couple of years. I’ve been using Kwikset deadbolts for about 8 years now and they work fine when it is cold or hot. The key is to make sure things are aligned well and properly adjusted. The Kwiksets and most other z-wave locks can alert you if they jam or don’t lock properly. It does happen occasionally when the kids don’t close the door properly.
              Great thx i will wait for boxing day to see if there is rebate.
              Thx
                Aartech.ca has their boxing sale on already I believe. Best place in Canada to buy HA equipment.
                  Yes !! I love aartech
                    These are the ones I have: https://www.aartech.ca/9ged14950-005.html. They used to be branded as Kwikset in Canada, but are now branded as Weiser here (still Kwikset in the US).
                      Oo nice that is a great price
                        I have Schlage locks and find they work quite well but I'm in North Carolina so I never see -40. Mine are the older Z-Wave locks, but I know Schlage was supposed to release Z-Wave Plus versions this month. If you are interested in Schlage, my suggestion is to wait for the Plus model as you'll get better range and easier pairing.
                        This listing indicatest they are "New Model" so perhaps they are the z-wave plus version, but I'd want to confirm that with the seller first. https://www.amazon.com/Schlage-Conne...rt+Home+Direct
                        Also, FYI, you can see a full listing of all available locks and their features here: https://products.z-wavealliance.org/...ies/6/products
                          Do you have a storm door protecting the inside door from the elements? If not, I wonder how much it would help the lock from the elements.
                            No unfortunatly
                              I live in Quebec and for the last 6 years I have been using 3 Yale YRD210 without any issues, like Sparkman mentionned in a post earlier you need to make sure of a perfect alignment of the deadlock and the hole in the door frame
                              I also highly recommend Aartech as your Canadian supplier, they have good price and the best customer service.
