Can't start Z-Wave interface
    Hi,
    I never been lucky with Z-Wave. I just bough a Zooz 4-in-1 sensor. But my Z-wave interface isn't working anymore...
    WARNING: Failed getting InterfaceStatus from Z-Wave - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    Any idea on what is causing this issue?
    What kind of interface? How is it connected to HomeSeer? What does it show on the Z-Wave Controller Management page?
    I have seen an interface drop off when including a device. A restart of HomeSeer will usually get it to reconnect.
    Randy Prade
    Aurora, CO
    Prades.net
      Hi RPrade,
      I have a Smartstick+. It's connect to a USB port on my HS server running Windows 10. The interface just don't start. So I have no Z-Wave menu under Plug-ins.
        That sounds like the plug-in is not running. I don’t see how you could get the error you posted at the top without the plug in running. Does the plug-in show on the Management page? If the plug-in is not there, you can reinstall it.
        Randy Prade
        Aurora, CO
        Prades.net
          This is what I have in the Management page:
            That is odd. I would try restarting HomeSeer and the computer. If you still have the same issue, try reinstalling the plug-in.
            Randy Prade
            Aurora, CO
            Prades.net
              I stopped HS, deleted everything about Z-Wave. Restart my server. The I installed the Z-Wave plugin. Again, same error message. No luck.
                Check the HS3 root folder for DLL conflicts. All the DLL's that the plugin uses are placed in the bin/Z-Wave subfolder. If there are any DLL's in the root folder with the same names of those, there will be a conflict if the file versions differ. Specifically, Newtonsoft.Json.dll is widely used and some misbehaving plugins have installed it in the root in the past (thankfully none do this currently).
                  Thank you Zwolfpack! It was effectively that Newtonsoft.Json.Dll that was in the root folder. Removed it from root and now it is working,
