A problem with Z-wave nodes connectivity
  • A problem with Z-wave nodes connectivity
    It seems that I have Z-wave issues.
    I had a module that was repeatedly unresponsive so I removed it and then, went into the Z-Wave controller screen and ran the "Test Connectivity on a Network" and to my dismay it appears my problem is bigger than I realized.
    Some background
    I have 2 or 3 devices outdoors that are currently powered off for the winter (Pool heater, pump etc.) at the sub-panel, plus a sprinkler controller - not sure if that contributes to the problem.
    The symptom I've been noticing lately is that some devices are initially not responsive via Google Home and then they are on a second attempt (might be a whole unrelated problem - I can't tell).
    Although the connectivity test suggests some devices did not respond, most, if not all appear to be generally working.
    Any suggestions/recommendations would be appreciated.
    Here is the results from Test Node effort....
    Obtaining a list of nodes to be contacted...
    26 nodes will be contacted, the following nodes will be skipped: 1 9 10 21 22 23 24 30 39 40
    Node 2 (First Floor Family Room HSM200) Successfully contacted.
    Node 3 (First Floor Living Room Pole lamp 2) Successfully contacted.
    Node 5 (First Floor Living Room Pole lamp 1) Successfully contacted.
    Node 6 (Outside Upper Deck Upper deck sconce) Successfully contacted.
    Node 7 (Outside Lower deck Lower deck sconce) Successfully contacted.
    Node 11 (Outside Pool Controls Pool Heater z) did not respond.
    Node 13 (Outside Front of house Outside Christmas lights) did not respond.
    Node 14 (Outside Ground Level East yard floodlight) did not respond.
    Node 15 (Bedroom Level Master Bedroom Multi-Sensor #2) did not respond.
    Node 16 (First Floor Living Room Multi-Sensor #1) did not respond.
    Node 17 (Kitchen-level Kitchen Multi-Sensor #3) did not respond.
    Node 18 (Basement Rec Room (unused) - needs to be re-set) did not respond.
    Node 19 (First Floor Family Room Table Lamp) did not respond.
    Node 20 (First Floor Family Room Pole Lamp) did not respond.
    Node 25 (Outside Side porch Side porch light) did not respond.
    Node 26 (Kitchen-level Kitchen Kitchen Fan) did not respond.
    Node 27 (Basement Outside office Power Panel Light) did not respond.
    Node 28 (Bedroom Level BedRoom2 Table Lamp (window)) did not respond.
    Node 33 (Outside Ground Level HomeSeer Sensor - FLS100 - Pool) Successfully contacted.
    Node 35 (Outside Pool Controls Aeon Labs Switch Binary (Pool pump controller)) did not respond.
    Node 36 (Outside Gardens GoControl Irrigation Controller) did not respond.
    Node 37 (Outside Upper Deck HomeSeer Sensor - FLS100 - Kitchen Window) did not respond.
    Node 41 (Bedroom Level Master Bedroom Blue lamp) did not respond.
    Node 42 (Bedroom Level Master Bedroom Purple lamp) did not respond.
    Node 43 (First Floor Foyer Table Lamp) did not respond.
    Node 44 (First Floor Foyer Foyer Christmas Tree) did not respond.
    Finished!
    -steve
    Current Date/Time: 12/28/2018 10:34:31 AM
    HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.475
    Linux version: Linux HomeTrollerZeeS2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 1 Day 17 Hours 52 Minutes 11 Seconds
    IP Address: 192.168.15.10
    Number of Devices: 220
    Number of Events: 246
    Available Threads: 399
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed:
    Enabled Plug-Ins
    3.0.0.5: CM15A
    3.0.0.54: EasyTrigger
    3.0.0.18: EnvCan
    3.0.1.249: Z-Wave
