Hi,
I bought a couple of Fibaro dimmer 2 modules with din rail mounts to install them in my electricity clauset. I have only 1 pair of cables running to the (single) momentary switches.
On S1 there is no tripple click scene, on S2 there is. I could wire the switch to S2, but then it wont control the light. I can link s1 to s2 in homeseer to make that work, however in the case my HS machine is down, you wont be able to control the light with the switch anymore...
Is there a way i can have a tripple click scene using only 1 physical switch AND still be able to directly control the light with it?
Thanks in advance!
Verstuurd vanaf mijn SM-G965F met Tapatalk
Thanks in advance!
