I am going to be replacing a couple switches that are GE Zwave switches with either GE Zwave Plus or HomeSeer Zwave Plus switches.
If I upgrade from GE Zwave to GE Zwave Plus can I simply do a replace node and optimize/ audit or will this not work properly and I need to remove and add the new zwave plus switch as a new switch?
If I go with HomeSeer Switches I assume then the answer is remove and add, but depending on replace vs remove and add may depend on what switches I go with.
