I have the exact same problem. My Z-Net Z-Wave controller keeps adding new devices as node 16, overwriting the old node. It only does 16 now for the last 3 devices I've tried. I did all the above, nothing changes. Really annoying. About ready to give up and move to another controller software, as if I have to redo everything from scratch, I might as well try something else.
Zwave device adds/remove has become beyond flakey
Guest
Originally posted by upstatemike View PostIt's stories like these that make me afraid to try Z-Wave.
What version of Z-Wave plugin is being ran? Is it Beta? I know from having to install/re-install exlude/include an entire environment that when playing with Beta's sometimes you get burned.
If it's not the Beta Z-Wave plugin then it's a problem and I would take it to support.
I had the same issue with the GA release and the beta. I engaged homeseer support and they were very nice, but completely unhelpful - in fact some of the things they recommended made the problem worse.
I think I may have solved my issue though. Readers digest version is that I feel the single znet that I had with 70 devices (some of them power and water meters that update data every 1-10 seconds) was being overwhelmed. I added a new znet with a new network ID (adding as a secondary DID NOT HELP) and took the nodes that were reporting a lot of data off of the original znet and added them into the new one (7 nodes). Everything has been very stable ever since. Knock on wood.
Originally posted by grahamk View PostI had the same issue with the GA release and the beta. I engaged homeseer support and they were very nice, but completely unhelpful - in fact some of the things they recommended made the problem worse.
I have 2 power meters that report every 10 seconds. I need to be able to take action based upon power switching from one leg to another. I could probably monitor less often, but I would prefer not to. Frankly, in the world of data transfer, 2 values every 10 seconds is pretty small. I'm surprised, but not shocked, that it caused zwave issues. I think it was more likely due to the amount of nodes.
Originally posted by grahamk View PostI have 2 power meters that report every 10 seconds. I need to be able to take action based upon power switching from one leg to another. I could probably monitor less often, but I would prefer not to. Frankly, in the world of data transfer, 2 values every 10 seconds is pretty small. I'm surprised, but not shocked, that it caused zwave issues. I think it was more likely due to the amount of nodes.
Real time events - I have very bad power with an automatic backup generator on a transfer switch that is somewhat underrated for the house. If power goes out and stays out for 10 seconds the generator will kick in - at that point I need to quickly turn off switches to major power users such as the hot tub, water heater, etc or I risk burning up my generator. So I have less than 10 seconds to make the decision. I really ought to monitor at 5 seconds now that I can. ;-)
Water usage - I have a very low producing well that only has a certain capacity. If water runs I need to keep very close track of where things stand around the capacity of the well vs. water used. I do not want to run my well down too far or the pump will start picking up minerals at an incredibly high rate. So I monitor usage very closely and automatically turn off the water main if resources get too low. Also - along those lines, I very closely monitor for running water - something that might run the well dry if it continues at a certain rate. That will sound alarms, send e-mails and eventually turn off the water main as well.
First World Problems. :-)
Originally posted by grahamk View PostReal time events - I have very bad power with an automatic backup generator on a transfer switch that is somewhat underrated for the house. If power goes out and stays out for 10 seconds the generator will kick in - at that point I need to quickly turn off switches to major power users such as the hot tub, water heater, etc or I risk burning up my generator. So I have less than 10 seconds to make the decision. I really ought to monitor at 5 seconds now that I can. ;-)
FWIW - I found out how to log into the z-net and took a look around. As far as I can tell the znet module itself is doing next to nothing. Very few CPU cycles, extremely low load, plenty of free memory. So Z-wave network bandwidth must be the culprit. Would anyone happen to know how I might monitor how saturated a zwave network is becoming? IMO it would be great to drop warning in the log if it is reaching 80% or so or rated capacity.
Originally posted by grahamk View PostFWIW - I found out how to log into the z-net and took a look around. As far as I can tell the znet module itself is doing next to nothing. Very few CPU cycles, extremely low load, plenty of free memory. So Z-wave network bandwidth must be the culprit. Would anyone happen to know how I might monitor how saturated a zwave network is becoming? IMO it would be great to drop warning in the log if it is reaching 80% or so or rated capacity.
