Z-Wave Error: Dimmer node: 19
  • Z-Wave Error: Dimmer node: 19
    I have an event to turn the led on a WS200+ Switch to blink red when my Schlage is unlocked.
    I'm getting two errors:
    A Z-Wave action in the event If front door is unlocked, turn switch LEDs red Door is Unlocked Switch - Dimmer returned an incomplete (failed) result.
    Event Action Set Configuration Parameter to enable status mode failed in Event If front door is unlocked, turn switch LEDs red Door is Unlocked Switch - Dimmer node: 19
    Here's a screenshot of the event.
    Any ideas?
    Doug
    I'm receiving similar messages on my system as well -- seems to be around those new switches and setting configuration parameters. I had posted elsewhere on the forum, but haven't gotten any response. I'm up to date with HS3 Pro Edition 3.0.0.435 (Windows) and my events look very similar to yours. Hope someone chimes in with a solution. The strange thing is, at least for me, is it does appear to be setting the LED status correctly on my switches -- it's just throwing this error in the background (makes me think the response from the switch to HS is being interpreted incorrectly internally)
    Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
    Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
    Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
      I was seeing the same error and this may or may not apply to your situation.
      It turns out that I had taken one of the WX200s out of service two months ago and forgot about it.
      Events continued to run that controlled the now O-O-S WX200.
      Wiring the O-O-S unit back onto a circuit eliminated the errors immediately.
      Why the errors just started to occur is unknown.
      Hope this helps.
      T
        Well, after months -- still putting up with this. Tried resetting the switch (pulling the safety switch) and still have a ton of these messages. They seem to only happen on the HS200 switches and dimmers .. very frustrating. I've not removed any nodes, so tam's solution doesn't apply.
        May-20 9:44:14 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-20 9:14:15 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-20 8:22:14 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-20 8:00:00 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event Cabana Bath Cabana Bath Fan [1 TAP DOWN - OFF]
        May-20 7:52:14 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-20 7:52:14 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-20 7:22:14 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-20 7:18:14 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-20 7:14:28 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 7:11:34 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 7:11:04 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 7:06:39 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 6:48:14 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-20 6:33:55 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 6:33:32 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-20 6:30:00 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event Cabana Bath Cabana Bath Fan [1 TAP UP - TIMER ON] node: 63
        May-20 6:00:00 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBR MB Entry Light Status Light - [2200 Dim/Off]
        May-19 10:44:13 PM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBR MB Entry Light Status Light - [Temp Override, Night]
        May-19 10:44:03 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 10:42:26 PM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBR MB Entry Light Status Light - [Temp Override, Night]
        May-19 10:42:16 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 10:00:00 PM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBR MB Entry Light Status Light - [2200 Dim/Off]
        May-19 9:54:23 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 8:54:20 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 8:54:14 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 8:54:06 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 7:51:47 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 7:51:42 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 7:47:54 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 7:47:42 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 6:31:33 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 6:31:10 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 6:18:06 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 5:34:15 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBR MB Entry Status 5 - Small Garage Door Open node: 56
        May-19 5:04:09 PM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-19 4:34:09 PM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-19 10:46:07 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-19 10:16:07 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-19 9:52:06 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-19 9:22:06 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-19 9:21:06 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBath MBath Fan [OFF]
        May-19 8:51:06 AM Z-Wave Error Event Action Set Configuration Parameter to enable status mode failed in Event MBath MBath Fan [ON - TIMER ON] node: 55
        May-19 6:00:00 AM Z-Wave Error Event Action Set Configuration Parameter failed in Event MBR MB Entry Light Status Light - [2200 Dim/Off]
          Tried updating the firmware on the dimmer as well, still get the error. Anyone else seeing this? I seem to be getting this error on every hs-wd200 I have where i'm setting the status LEDs.
            Have you opened a ticket with HomeSeer support?
              For the record -- I was able to resolve this by re-installing the normal z-wave plugin. Apparently, I had one of the betas installed.
