Association & Group
  • Association & Group
    I have some Cooper master/slave light switches. These switches require association. In the past I had no issues doing this. However, now it doesn't work properly. When I go to "Associations" in the "Z-Wave" property of the device I can't select an "Association Group". Instead I can only select the "Device to be Controlled", click on "Add Association", then get an error which will populate the "Association Group" and then select "Add Association" again. These couple of mouse clicks are not the issue. I am worried that there is an underlying problem. I just erased my entire z-wave network and redo everything. The last thing I want to happen is that I need to redo everything again because that failed association messed things up. It's becoming quite a waste of time....
