I am in a condo and just took off a switch plate to look at wires. I see Ground, 2 black hots and a white neutral which is not attached to switch but coo extend to multiple whites. I see no load but one black is twisted into two others and one is a single. There are four lights total but only one switch. I’m attempting to install a HS-WS200+. I’m curious about the load which I assume is either the three blacks connected or the single. I’d guess the single.
Id also guess I need to piggy back off the neutral and connect that wire to the switch.
