Fibaro Walli - works in non secure mode.
  • Fibaro Walli - works in non secure mode.
    Fibaro has launched the walli series and i like to know if they are already supported by homeseer.
    They are not cheap and i don't want to buy them before i know that it works.
    in the end i asked homeseer support....
    "there are no plans to add support for the walli series"
      Would a z-wave device not "just work"? I never had any z-wave device that didn't work, if it had the right associations to homeseer.
        lurendrejer not always, "special features" most of the time not.
        but perhaps i will buy one en test it
        all my duwi wall dimmers and switches are old and some of them doesn't work anymore so i have to look for something to replace these
          Logichome's zhc series also comes in "gira sizes" - they work, and I love them.
            If homeseer supports the command classes that walli uses, I am pretty certain that it works.
            I have a few devices that has special needs, like zipato that requires a certain parameter to be set to activate 'blink', etc.
              Support stated that these may work unless they have classes not supported by HS3 so as others have stated if they are Z-Wave certified they should work with HS3 or partially work.
              -Rupp
                Rupp
                support stated two things:
                I can't guarantee that the controller and roller shutter will work
                engineers will be able to look into adding support for them, though there aren't any plans at this moment.
                i did not buy a "walli", but i will do in short time and we will see
                  It is woking, only when you add the device in non secure mode
                    If it is when using direct associations to dimmers, it might be because they are running non-secure.
                    Homeseer does support secure commands, so status updates etc should work either way.
                    Both directly associated devices should be either insucure or secure.
                      lurendrejer
                      If a use securemode, ik mis the second switch and some other things
                        and this is non secure
                          Thats quite odd, but rather interesting
