Originally posted by ericg
View Post
Light switches - Paddle or Toggle - that is the question
Originally posted by joegr View Post
The Insteon keypad that I posted would work there, but it could only directly control one of the three loads. You'd have to add in-line modules (controlled from other keys on the keypad) to actually switch the other two loads.
Can anyone recommend specific Z-wave in-line modules that are both reliable and reasonable cost?
You could go with aeon labs micro switches perhaps...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by ericg View Post
I have thought of using in-line modules controlled by (multi-tap) scene control from a single HS-WS200+. I don't presently have any Insteon, and I'd prefer to avoid it if possible.
If you have a half dozen or more loads you want to control with on/off, maybe some projects in other rooms, I'd suggest looking into an Arduino module with an ethernet shield and a relay board. Once you start getting above a certain number of circuits, the Arduino solution quickly excels at value for money.
