Push button (doorbell) interface
  • Push button (doorbell) interface
    Hi, haven't been around in a while so I'm not up on current Z-Wave devices. Several years ago, before Z-Wave, I wired my doorbell button to an x-10 Powerflash using it to detect a button push and send an x-10 signal to HS. Worked great but I'm having to move away from x-10 and I haven't yet found a Z-Wave device that will do this. The thing that makes this "challenging" is I don't want to replace the existing external wired button.
    The closest I've found is the Nexia Doorbell Sensor. It wires into the existing doorbell chime transformer unit. Not really what I want since I've removed that and am only using the two wires from the doorbell button. I did put a 110vac outlet up there to provide power and an x-10 path for the Powerflash.
    Really all I need is a Z-Wave device that I can wire the doorbell button to. Can be either battery powered or 110vac.
    Suggestions?
    Michael
    HS3, W10 Home, HSTouch, W800, Z-Stick+
    The Ecolink door/window sensor has contacts you could wire the switch to.
    HS 3.0.0.548: 1965 Devices 1146 Events
    Z-Wave 3.0.1.262: 122 Nodes on one Z-Net
      Looks perfect. Thanks!
      Michael
        Wondering how long the switch would have to remain closed to trigger the sensor. People tend to push and release a doorbell pretty quickly.
        Michael
          I've been using a few as sensors on doors/windows without issues for 5+ years. One is in use in regular mode with the magnet to detect an old metal security entry door from being opened, and others are in use to elevate an old NC security system (Normally Closed circuitry). Happy to report for you that response time is instant and even the shortest flash on closing contact, or the quickest disconnect/reconnect on the NC side is immediately reported to Z-Wave controller.
          It also has tamper alert via micro-switch inside case if somebody opens case/lid.
          Battery life has been impressive as well, almost ran 4-years on door sensor.
            My experience has been the same, in that it reports on a very short duration contact. The only drawback to them is that the tamper alarm does not reset automatically. See this thread for details:https://forums.homeseer.com/forum/li...s-tamper-alarm. A minor issue in my opinion.
              I'm using them for security purposes myself, so the fact I have to manually force a tamper-alarm reset as an authorized user (or automate it via handler) is my preference and perhaps Ecolink's reasoning behind it. Tamper alerts clearing themselves or clear via actions possible on the device would not be secure as the intrusion might then go undetected.
              Had to write an event for Schlage lock as well, because if the lock is configured to auto-lock itself after 30-seconds then HomeSeer remains showing "Unlocked" on the door lock status.
              An extra HomeSeer option to auto-clear would be nice though if the device supports it.
                Well, it works, sortof... Turns out my button is a little dicey. Probably old and a bit corroded - like my knees, but that's another issue...!
                Thanks for the suggestion and good solution.
                Michael
                  Cheaper doorbell buttons tend to oxidize quick, you can use like vinegar tricks, but DeOXIT would be preferable or a cheap can of electronic contact cleaner at car maintenance isle.
