Good morning all,
I have been migrating back to HS3 from ST from when I was originally on HS2 and HS3 so I'm familiar with the platform and nuances.
I reset all my switches before adding them back to homeseer and seem to be running into a few problem children. For example this one. I re-deleted it and added it back into the system. I also killed the power to it via the airgap on it to make sure it even rebooted the switch itself. Most of my z-wave switches are GE/Jasco (on/off and dimmers)
These are the errors I get just from adding and trying to send info to/from the device from HS or editing it:
Let me know what you think!
Thanks in advance!
Stephen
Oct-27 4:43:27 AM | Z-Wave Warning | Could not get the SWITCH command class version for node 26 . |
Oct-27 4:43:27 AM | Z-Wave Warning | Error getting version information for node 26, Send failed. |
Oct-27 4:43:26 AM | Z-Wave | Node: 26 Supports Class(es): SWITCH_MULTILEVEL_V3, SWITCH_ALL, POWERLEVEL, CONFIGURATION, VERSION, MANUFACTURER_SPECIFIC_V2 |
Oct-27 4:43:26 AM | Z-Wave | Syncing Z-Wave nodes with device list... |
Oct-27 4:43:26 AM | Z-Wave | Found 34 Z-Wave nodes |
Oct-27 4:43:26 AM | Z-Wave | Getting Z-Wave node list for network 0184E037... |
Oct-27 4:42:50 AM | Z-Wave Error | Failed sending Z-Wave command to device: Node 26 Z-Wave Murano Chandelier |
Oct-27 4:42:50 AM | Device Control | Device: Node 26 Z-Wave Murano Chandelier to Dim (value)% (40) by/from: CAPI Control Handler |
Oct-27 4:42:49 AM | Z-Wave Error | Failed sending Z-Wave command to device: Node 26 Z-Wave Murano Chandelier |
Oct-27 4:42:49 AM | Device Control | Device: Node 26 Z-Wave Murano Chandelier to Dim (value)% (48) by/from: CAPI Control Handler |
Oct-27 4:42:44 AM | Z-Wave Error | Failed sending Z-Wave command to device: Node 26 Z-Wave Murano Chandelier |
Oct-27 4:42:44 AM | Device Control | Device: Node 26 Z-Wave Murano Chandelier to Dim (value)% (30) by/from: CAPI Control Handler |
Oct-27 4:41:36 AM | Z-Wave Warning | Could not get the SWITCH command class version for node 26 . |
Oct-27 4:41:36 AM | Z-Wave Warning | Error getting version information for node 26, Send failed. |
Oct-27 4:41:35 AM | Z-Wave | Node: 26 Supports Class(es): SWITCH_MULTILEVEL_V3, SWITCH_ALL, POWERLEVEL, CONFIGURATION, VERSION, MANUFACTURER_SPECIFIC_V2 |
Oct-27 4:41:35 AM | Z-Wave | Syncing Z-Wave nodes with device list... |
Oct-27 4:41:35 AM | Z-Wave | Found 34 Z-Wave nodes |
Oct-27 4:41:35 AM | Z-Wave | Getting Z-Wave node list for network 0184E037... |
Oct-27 4:39:16 AM | Z-Wave Warning | Could not get the SWITCH command class version for node 26 . |
Oct-27 4:39:16 AM | Z-Wave Warning | Error getting version information for node 26, Send failed. |
Oct-27 4:39:15 AM | Z-Wave | Node: 26 Supports Class(es): SWITCH_MULTILEVEL_V3, SWITCH_ALL, POWERLEVEL, CONFIGURATION, VERSION, MANUFACTURER_SPECIFIC_V2 |
Oct-27 4:39:14 AM | Z-Wave | Synchronize nodes finished. Number of device nodes to be created/added = 1 |
Oct-27 4:39:10 AM | Z-Wave | Done. Node 26 Added. |
Thanks in advance!
Stephen
