Good Afternoon,
I've been searching and searching and nothing I've found seems to speak to this particular issue.
Just the facts please...
- HS3 on windows 7 - Been running for years with no issues. One Z-Troller, it is the only controller.
- Out of the blue began getting "Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect."
- Began not having fun...
- Been meaning to upgrade to HS4 (Linux). Just so happens I'd made preparations for Linux already (another computer built with Linux Mint 20 installed).
- Began HS4 installation. I'm doing it clean because anything else would just be a magnet for problems. Sure, It'll take me days to add back all my stuff but at least it'll work.
- Came time to install the Z-Wave plugin and guess what... "Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect." New hardware. Clean installation. Same problem.🤨
- I figured I needed to factory reset the Z-troller so...
- Can't do it in HS4 or HS3 because the error prevents access to the Z-Troller through the plugin.
- Unplugged, removed batteries, and left if overnight... no joy.
- Wept softly.
- Turning to the community because frustration loves company.
