About 2 months ago I started seeing daily Z-Wave errors on two or three devices... so following some old threads I used the plugin to 'reset' the zwave data (routing data) and now, its worse than before and getting errors on all but a few zwave devices. Looks like issues with wall-powered appliance switches (GE & Aeotec), two Schlague doorlocks, and three Dome battery powered chimes/sirens.
Not seeing errors/logs for the 4x Zooz ZEN72 (dimmers installed in the past 3-4 months) or any of my 10 multi-motion sensors and many other zwave battery devices (water sensors, etc) The zwave devices and the HS3 PC / Z-stick do not move so routing should not be changing.
I optimized (in the zwave plugin) the Zooz dimmers and the appliance modules (which get errors) since those are adjacent to many of the battery devices and somewhat scattered around the house evenly.
Help is highly appreciated!
log...
log...
Nov-28 4:03:16 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-28 4:03:03 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-28 1:37:54 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-28 1:37:41 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-28 1:17:52 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-28 1:17:39 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 10:12:37 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 10:12:13 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 9:30:08 PM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-27 7:47:16 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 7:46:52 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 6:42:00 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 6:41:47 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 10:25:42 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 10:25:29 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 8:40:28 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 8:40:15 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 7:40:17 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 7:40:04 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 3:09:49 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 3:09:24 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 2:49:36 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-27 2:49:22 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-26 9:55:50 PM | Z-Wave Error | Failed sending Z-Wave command to device: Bedrooms Master Night Stand Lights |
Nov-26 8:58:48 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-26 8:58:35 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-26 8:38:57 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-26 8:38:33 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-26 11:42:04 AM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Mudroom Lock |
Nov-26 11:41:04 AM | Z-Wave Error | Failed sending Z-Wave command to device: Bedrooms Master Night Stand Lights |
Nov-26 11:40:04 AM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-26 11:33:59 AM | Z-Wave Error | SmartStick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (SmartStick). |
Nov-26 11:31:00 AM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-25 2:46:07 PM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Entry Door Lock |
Nov-25 10:58:43 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 10:58:29 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 8:53:20 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 8:53:07 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 6:07:44 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 5:23:02 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 5:22:49 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 4:00:08 AM | Z-Wave Error | Failed sending Z-Wave command to device: Basement Mechanical Sump |
Nov-25 1:37:28 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-25 1:37:04 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 10:52:33 PM | Z-Wave Error | Failed sending Z-Wave command to device: Bedrooms Master Night Stand Lights |
Nov-24 10:32:02 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 10:31:38 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 8:46:07 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 8:45:54 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 8:45:09 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 8:44:56 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 8:44:43 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 8:44:30 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 8:44:17 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-24 7:00:21 PM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-24 7:00:08 PM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-24 6:44:53 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 6:44:53 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 6:44:27 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 6:43:11 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-24 5:37:35 PM | Z-Wave Error | Failed sending Z-Wave command to device: Bedrooms Master Night Stand Lights |
Nov-24 2:30:44 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 2:30:31 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 12:05:25 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 12:05:12 PM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-24 11:54:03 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 11:53:33 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 11:52:33 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 11:52:10 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 11:51:31 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 11:51:18 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 11:51:05 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-24 10:50:48 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-24 10:50:35 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-24 10:50:22 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-24 10:48:28 AM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-24 1:00:08 AM | Z-Wave Error | Failed sending Z-Wave command to device: Basement Mechanical Sump |
Nov-23 9:12:34 PM | Z-Wave Error | Failed sending Z-Wave command to device: Main Dining Room Light |
Nov-23 8:30:21 PM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Entry Door Lock |
Nov-23 8:30:08 PM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Mudroom Lock |
Nov-23 1:19:51 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-23 1:19:26 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-23 1:19:13 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-23 1:19:00 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-23 1:18:36 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-23 1:18:23 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-23 1:18:10 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-23 1:17:44 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Deck Switch |
Nov-23 1:17:31 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Entry Switch |
Nov-23 1:17:26 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Stairs Switch |
Nov-23 1:15:05 PM | Z-Wave Error | Failed sending Z-Wave command to device: Dome Siren Garage Siren |
Nov-23 10:10:27 AM | Z-Wave Error | SmartStick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (SmartStick). |
Nov-23 6:01:21 AM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-23 6:01:08 AM | Z-Wave Error | Failed sending Z-Wave command to device: Main Kitchen Espresso Machine |
Nov-23 5:16:15 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-23 5:16:02 AM | Z-Wave Error | Failed sending Z-Wave command to device: Blue-Iris Cameras Kitchen Switch |
Nov-23 4:59:09 AM | Z-Wave Error | SmartStick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (SmartStick). |
Nov-23 2:54:05 AM | Z-Wave Error | SmartStick: Error, the Z-Wave API Transmit Queue is not empty after waiting 20 seconds - the interface may be disconnected or not operational (SmartStick). |
Nov-22 4:09:33 PM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Entry Door Lock |
Nov-22 4:09:19 PM | Z-Wave Error | Failed sending Z-Wave command to device: Door Lock Mudroom Lock |
