Aloha fellow HS users,
I installed 21 of the Aeotec 7 recessed door sensors in a client's house to manage their air conditioners when the doors are open/closed. Running HS4 4.2.6 on a Windows HometrollerPlusG1 and using Z-wave plugin 3.0.9.0. All is working well but I have a question about the objects that get created and their behavior.
When paired to the Z-Wave network these create several objects including one called "Sensor Binary Door_Window" and one called "Access Control Notification". When the sensor reports open or closed changes, only the Access Control Notification object changes to reflect the new state. The Sensor Binary Door_Window object shows "Closed" all the time and the Web UI shows no changes have ever been made (no change time) to these objects in the weeks they have been running. The plugin works fine generally and I get what I need from the sensors reliably but it seems odd that this field is created but (apparently) never used. I've used previous revs of these same sensors on HS3 and the roles are reversed. The Access Control Notification never changes and the Sensor Binary Door_Window (might be slightly differently named when created on HS3) reflects the open/closed changes.
As I said, I've got what I needed but is there any reason why this changed between HS3 and HS4? And perhaps why not have both objects created reflect the state changes? It's admittedly redundant but why create an object that (apparently) doesn't report what it seems to represent. Is the Sensor Binary Door_Window object deprecated but still being created? I guess it could also be the Aeotec 7 units operate differently than the previous models I have under HS3 as well. I see this behavior consistently across all 21 sensors.
Anybody know the history or logic behind how these are working?
Mahalo!
-HAH
Mahalo!
-HAH
