Unable to fully add Neo Power Plug - Solved!
    Trying to add a Neo Power Plug. The device was found for the Add, but only the root and two child devices were found. I can control the device but I get no power reporting (Vac, W, kWH). I did a re-scan, but the results are the same. The device isn't far from the z-Net. Both for the add and rescan, I get the following log entries:
    Feb-25 14:12:03 Z-Wave 2 out of 2 Child devices of node 16 were created successfully.
    Feb-25 14:12:03 Z-Wave All associations for node 16 have been retrieved successfully, it supports associations on these groups: 1, 2.
    Feb-25 14:12:03 Z-Wave Node 16 Association Group 2 can have 5 associations, and currently has 0
    Feb-25 14:12:03 Z-Wave Node 16 Association Group 1 can have 5 associations, and currently has 1
    Feb-25 14:12:03 Z-Wave Getting association information for node 16
    Feb-25 14:12:03 Z-Wave Power_Management Supports Events: Over Load Detected
    Feb-25 14:12:03 Z-Wave Node 16 Supports 1 Notification Types: Power_Management
    Feb-25 14:11:37 Z-Wave Node 16 is a Z-Wave Plus node. Retrieving ZWPlus Info...
    Feb-25 14:11:37 Z-Wave Node 16 is Z-Wave version: Lib: 6.04 App: 2.23
    Feb-25 14:11:22 Fountain Increasing winds (Temp=47.1ΒΊ, Wind=9 mph, Avg=8.1, Gust=9)
    Feb-25 14:11:16 Z-Wave Node: 16 Supports Class(es): ZWAVEPLUS_INFO, SECURITY, SECURITY_2, TRANSPORT_SERVICE, POWERLEVEL, VERSION, ASSOCIATION, MULTI_INSTANCE_ASSOCIATION, ASSOCIATION_GRP_INFO_V2, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, SWITCH_BINARY, METER_V2, NOTIFICATION_V6, CONFIGURATION, SUPERVISION
    Feb-25 14:11:16 Z-Wave Warning If this is an import, you may need to remove and add the device as some devices cannot be added with an import.
    Feb-25 14:11:16 Z-Wave Warning Failed to get a SECURITY SCHEME or verify the key from node 16. Device may not be added properly to HomeSeer.
    Feb-25 14:11:16 Z-Wave Error Z-Wave was unable to negotiate a compatible security scheme with node 16
    Feb-25 14:11:06 Z-Wave Adding using S0 Security, Negotiating or Verifying SECURITY SCHEME for node 16
    Any suggestions would be appreciated.
    HS3 Pro Edition 3.0.0.548 (Windows), Z-Wave 3.0.9.0
    Try removing the device and adding it using the non secure mode.
    πŸ’β€β™‚οΈ Support & Customer Service πŸ™‹β€β™‚οΈ Sales Questions πŸ›’ Shop HomeSeer Products​
      Humph. Worked. Thanks, Rupp. I've always been under the impression 'older' devices had to be added non-secure, but reading the header it sounds like I would be better off adding everything in non-secure mode unless a secure connection is required (locks etc.). Is that interpretation correct?
