Stick7 on a RPi with Ser2Net
    I want to relocate my Stick7 and attempted to use RPi4 with Ser2Net. Installed Pi OS Lite (Debian v11) and Ser2Net. Plugged in stick and identified it as 'ttyUSB0'. Fixed IP and checked connection from Windows PC ok. Configured ser2net.conf with '2001:raw:0:/dev/ttyUSB0:115200 8DATABITS NONE 1STOPBIT -XONXOFF -RTSCTS' but couldn't get HS4\z-wave plugin to recognise it.
    Stick works directly plugged into HS4 PC okay.
    Anyone be able to advise? I did have Z-net SD card and tried using that, but the image I think is too old as it didnt even detect Stick to configure.
    Essentially my goal is to get my stick accessible on RPi4 just as remote interface so my Windows\HS4 can access it.
    HS4 Pro Edition 4.2.13.0 (Windows), BLBackup 2.0.63.0,BLDenon 2.0.58.0,BLLAN 2.0.45.0,BLOccupied 2.0.28.0,BLPlex 2.0.22.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,BLUPS 2.0.26.0,JowiHue 2.1.2.1,Modbus 3.9.6431.26038,Pushover 3P 0.0.0.52,RaspberryIO 3.0.0.20,SMS-Gateway 3.3.5.17921,Z-Wave 3.0.10.0
    Check ser2net status via
    ser2net -v
    and
    service ser2net status
    The command line is shown in the 'service' command output. The configuration file is specified via the '-c' option.
    On Debian 11, I believe you'll find that you're running ser2net version 4. With this, the configuration file is changed to 'ser2net.yaml', which has a different format than the old ser2net.conf.
    Try setting the config as follows. Indentation is important.
    %YAML 1.1
    default:
      value: true
    default:
      value: 115200n81
    connection: &con2001
      accepter: tcp,2001
      timeout: 120
      enable: on
      connector: serialdev,/dev/ttyUSB0
    Edit: to fix an issue mentioned in another thread, where ser2net doesn't start properly at reboot, edit file /lib/systemd/system/ser2net.service and add the lines shown below (starting with 'After=').
    [Unit]
    Description=Serial port to network proxy
    Documentation=man:ser2net(8)
    After=network-online.target remote-fs.target
    Wants=network-online.target remote-fs.target
    [Service]
    EnvironmentFile=-/etc/default/ser2net
    ExecStart=/usr/sbin/ser2net -n -c $CONFFILE -P /run/ser2net.pid
    Type=exec
    Restart=on-failure
    [Install]
    WantedBy=multi-user.target
      zwolfpack I'm struggling. I'm just a simple linux starter. However, I checked the ser2net version, and as you highlighted for ver 4, I edited the ser2net.service with adding 4th line and also the YAML file with your suggested code (with correct double space on indentations) but had raspberrypi ser2net[354]: Invalid port name/number: Invalid data to parameter on line 16 column 0 (last line of Yaml file). I also tried various other formats found HERE with same parameters. Reboot inbetween. But still Invalid error. In HS4, I'm using ethernet connection with IP address (fixed) and correct port as per Yaml. I also had a go with Trueport on a Windows PC to try and connect, but no luck. Rpi to HS4\PC is on same subnet\LAN.
      I've confirmed interface using tail -f /var/log/syslog and get usb 1-1.3: cp210x converter now attached to ttyUSB0. So obviously your config was same.
      What am I missing?
        I don't know. I just verified the setup on a RPi4. Before I was using a Pi3, but the Pi4 works the same.
        Suggest following the steps below and post details of any differences encountered.
        System info:
        pi@HS4Pro:~ $ uname -a
        Linux HS4Pro 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
        pi@HS4Pro:~ $ more /etc/os-release
        PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="11"
        VERSION="11 (bullseye)"
        VERSION_CODENAME=bullseye
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Steps performed...
        1) install ser2net
        sudo apt install -y ser2net
        1a) verify ser2net version
        pi@HS4Pro:~ $ ser2net -v
        ser2net version 4.3.3
        2) replace /etc/ser2net.yaml with
        %YAML 1.1
        default:
          value: true
        default:
          value: 115200n81
          accepter: tcp,2001
          timeout: 120
          enable: on
        3) Add lines to /lib/systemd/system/ser2net.service
        [Unit]
        [Service]
        Type=exec
        Restart=on-failure
        RestartSec=5
        [Install]
        4) reboot
        5) verify service running correctly
        pi@HS4Pro:~ $ service ser2net status
        ● ser2net.service - Serial port to network proxy
        Loaded: loaded (/lib/systemd/system/ser2net.service; enabled; vendor prese>
        Active: active (running) since Sun 2022-08-14 13:38:52 PDT; 34s ago
        Docs: man:ser2net(8)
        Main PID: 615 (ser2net)
        Tasks: 1 (limit: 4915)
        CPU: 21ms
        CGroup: /system.slice/ser2net.service
        └─615 /usr/sbin/ser2net -n -c /etc/ser2net.yaml -P /run/ser2net.pid
        Aug 14 13:38:52 HS4Pro systemd[1]: Starting Serial port to network proxy...
        Aug 14 13:38:52 HS4Pro systemd[1]: Started Serial port to network proxy.
        6) verify by adding Z-Wave controller to HS4 - see image.
          zwolfpack. I followed every instruction with a different Pi and fresh install but still failed. However, I come across THIS and added in /lib/systemd/system/ser2net.service the following:
          from the 4th line and it worked ! Thank you :-)
          EDIT: Although it's working fine, for some reason, my log keep registering an error "Zstick7: The serial port (COM2) was not found in the system. Will keep waiting for it..." from when is was directly connected. Any suggestions? Only have one plugin (3.0.10.0) with one interface to ethernet interface.
            After a great deal of trial-and-error and searching the web, I have gotten this to work on an RPi 3. I was getting the error "ser2net invalid port name/number." The solution came from this site: https://github.com/cminyard/ser2net/issues/52.
            In the folder /lib/systemd/system, I edited the ser2net.service file by adding "Requires=network.target" under [Unit]; and added [Timer] with the lines "OnBootSec=1m" and "Unit=ser2net.service".
            "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
