Has anyone experience with the HELTUN High Load Switch HE-HLS01 in combination with HomeSeer?
John
John
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
Add Node started... Activate the 'Add to Network' function on the device... Activate the 'Add to Network' function on the device... A new node is being added... Adding a new SLAVE NODE... DONE - Add Node Operation is Complete. Done. Node 10 Added. Reloading (importing) node information... Synchronizing node information with HomeSeer and creating new device(s) as necessary... Synchronize nodes finished. Number of device nodes to be created/added = 1 Adding using S0 Security, Negotiating or Verifying SECURITY SCHEME for node 10 Z-Wave Security Scheme and Key Exchange was successful for node 10, now waiting for the device to finish storing information before proceeding... Getting SECURITY class information for node 10 Z-Wave manufacturer information for node 10, ID: 836=344H (UNKNOWN), Type: 4=4H, ID: 10=AH Node: 10 Supports Class(es): ZWAVEPLUS_INFO, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, MULTI_INSTANCE_ASSOCIATION, TRANSPORT_SERVICE, VERSION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, INDICATOR, SECURITY, SECURITY_2, SUPERVISION, METER_V2, CONFIGURATION, THERMOSTAT_OPERATING_STATE_V2, THERMOSTAT_MODE_V3, THERMOSTAT_SETPOINT, SENSOR_MULTILEVEL_V8, CLOCK, NOTIFICATION_V6, APPLICATION_STATUS, FIRMWARE_UPDATE_MD Node: 10 Supports Secure Class(es): ASSOCIATION, ASSOCIATION_GRP_INFO_V2, MULTI_INSTANCE_ASSOCIATION, VERSION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, INDICATOR, METER_V2, CONFIGURATION, THERMOSTAT_OPERATING_STATE_V2, THERMOSTAT_MODE_V3, THERMOSTAT_SETPOINT, SENSOR_MULTILEVEL_V8, CLOCK, NOTIFICATION_V6, FIRMWARE_UPDATE_MD Node 10 is Z-Wave version: Lib: 7,11 App: 1.2 Node 10 is a Z-Wave Plus node. Retrieving ZWPlus Info... Node 10 Supports 3 Notification Types: Heat Power_Management System Heat Supports Events: Overheat Detected Unknown Location(2), Rapid Temperature Rise Unknown Location(4) Power_Management Supports Events: AC Mains Disconnected(2), AC Mains ReConnected(3), Surge Detected(4), Voltage Drop Drift(5), Over Current Detected(6), Over Voltage Detected(7), Over Load Detected(8), Load Error(9) System Supports Events: System Hardware Failure OEM Failure Code(3) Node 10 Supports Thermostat Mode CC and supports these modes: Off, Heat, Dry Air, Auto Change, Energy Save Heat, Away Node 10 Supports Thermostat Setpoint CC and supports these setpoints: Heating 1, Dry Air, Auto Changeover, Energy Save Heating, Away Heating All associations for node 10 have been retrieved successfully, it supports associations on these groups: 1, 2, 3, 4. Root Node Device Node 10 Z-Wave Thermostat was created for node 10 on network XXXXXXXX Aeotec Z-stick: Adding association for Z-Wave device Node 10 Z-Wave Thermostat (Node 10, Group 1) to HomeSeer 15 out of 15 Child devices of node 10 were created successfully. Finished. Saving network information to file: XXXXXXXX.nodes. Please wait... Done!
