Latest USB Interface Drivers
This is a sticky topic.
  • #16
    Bit further on
    Ok got my zwave and IRTrans to work together by changing the files but now I cant have any usb serial convertors running at the same time if I do it comes up not seeing the zwave in homeseer again.
    • #17
      Same problem with rfxcom and z-wave
      Hi I'm experiencing the same problem.
      I've unplugged the rfxcom and z-wave device, uninstalled the z-wave driver and the ftdi-drivers I had installed for the rfxcom.
      Next I downloaded the latest ftdi drivers and altered the inf files (this step might need a more detailed description for some). Plugged in the z-wave, and i let windows instal the latest (modified) driver. Started homeseer and the z-wave device turned out to work perfectly with the latest ftdi driver.
      Next I plugged in the rfxcom (usb transmitter), let windows install the same driver for this device as wel... started homeseer and it stopped recognizing the z-wave again. (If I unplug the rfxcom, then z-wave works again.)
      Who can resolve this?
      (an alternative z-wave device might also be a solution, the only one I know of, for europe, is the ACT ZCU010. RFXCom does add quite some functionality, I hope I won't end up having to choose between rfxcom and z-wave)
      • #18
        for the moment i'm living without RFXCom as I need my Z-Wave more
        Malcolm
        • #19
          here the same problem.
          i must choose between zwave or rfxcom
          ideas are welcome
          • #20
            RFXCOM uses the standard and unmodified drivers from FTDI so it can't be solved by RFXCOM.
            Did anybody report this problem to the Z-Wave supplier?
            Bert
            • #21
              I hope this solution will work for you:
              1 remove the ZWave device in the Homeseer Setup-Interfaces tab
              2 stop Homeseer.
              3 delete the ZWave and the RFXCOM USB devices from the Hardware-Devices
              4 uninstall the old FTDI drivers
              5 unzip the attached driver files to your disk. (but don't install them at this point)
              6 connect the zwave and the RFXCOM receiver. Don't install the drivers automatically but install them from the location where you unzipped the drivers.
              7 check the COM port which is assigned to the Zwave device (is in the Hardware-Devices list)
              8 start Homeseer and connect the Zwave device but now using the COM port.
              It should work now. I have installed the ZWave device using this procedure and the HS log shows:
              22-7-2007 17:29:51 ~!~Startup~!~Initializing Z-Wave Interface on COM port: 17 at 115K baud.
              22-7-2007 17:29:51 ~!~Info~!~Found 0 Z-Wave nodes
              22-7-2007 17:29:51 ~!~Info~!~Z-Wave interface version: 4
              22-7-2007 17:29:51 ~!~Info~!~Z-Wave interface node ID: 1
              22-7-2007 17:29:51 ~!~Startup~!~Initializing Plug-Ins
              22-7-2007 17:29:51 ~!~Z-Wave~!~Controller firmware version: 2.45
              The attached zip file contains the latest FTDI drivers with modified .INF files for the ZWave device. You will get a warning that the drivers are not certified. This is normal because the .INF are updated for the Zwave.
              Bert
              • #22
                Act Zcu201
                I have just installed HS2.2.066 and stopped.
                I am trying to install ACT ZCU201 USB adapter, Windows XPSP2 recognize it as a RS232 to USB adapter and cannot find the driver. Any of other USB drivers are not suitable. Any idea?
                • #23
                  You need to instal the port drivers from act.
                  http://www.act-solutions.com/HomePro/HomePro.shtml
                  • #24
                    Does anyone know where to find drivers for AspireRF RFUSB drivers for 64bit Win 7?
                    edit: I got the correct 64bit drivers from Cooper wiring but they are also available from www.FTDIchip.com
                    • #25
                      Wondering if there are any Intermatic HA-22 drivers out there for CE 6.0?
                      Just wondering? Trying out little experiment here.
                      - Pete
                      Auto mator
                      Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.00
                      Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.00
