Hi all,
I bought the Trane thermostat from HS, got it installed, added it to my HS network via my z-troller. Added the zwave thermostat plugin,created some events for it and every thing was running great for about a month. Now when HS starts, it has trouble sending commands to the thermostat shown in the log snippet below:
When I click on the zwave thermostat status button, I see multiple status blocks with nothing blank info shown in the attachment.
I am running HS2 v2.4.0.6. I tried upgrading to 2.4.0.11 with no change in result. Currently running 2.4.0.11 and z-seer 1.19
Not sure what the problem is or what to try next.
Mike
6/24/2010 7:34:12 PM - ZWave Thermostats - Error in GetSupportedModes: Return was null
6/24/2010 7:34:16 PM - Web Server - Web Server authorized local login successful from: 192.168.32.105 User: mmikem
6/24/2010 7:34:17 PM - ZWave Thermostats - Error in GetSupportedModes: Return was null
6/24/2010 7:34:22 PM - ZWave Thermostats - Error in GetSupportedFanModes: Return was null
6/24/2010 7:34:22 PM - ZWave Thermostats - Devices Updated for thermostat: Trane Thermostat
6/24/2010 7:34:27 PM - Network - Speaker client connected from: 127.0.0.1
6/24/2010 7:34:28 PM - Speaker - Speaker host added, Name: PCF IP address: 127.0.0.1
6/24/2010 7:34:33 PM - ZWave Thermostats - Error in GetSupportedModes: Return was null
6/24/2010 7:34:53 PM - ZWave Thermostats - Devices Updated for thermostat: Trane Thermostat
6/24/2010 7:35:38 PM - ZWave Thermostats - 1 Thermostats converted Successfully.
6/24/2010 7:36:03 PM - ZWave Thermostats - Devices Updated for thermostat: Trane Thermostat
6/24/2010 7:36:26 PM - Web Server - Web Server authorized local login successful from: 192.168.32.105 User: mmikem
6/24/2010 7:36:34 PM - ZWave Thermostats - Error sending ZWave Command, aborting: 43-2-2
6/24/2010 7:36:46 PM - ZWave Thermostats - Error sending ZWave Command, aborting: 40-2
6/24/2010 7:36:56 PM - ZWave Thermostats - Error sending ZWave Command, aborting: 42-2
6/24/2010 7:37:06 PM - ZWave Thermostats - Error sending ZWave Command, aborting: 44-2
6/24/2010 7:37:17 PM - ZWave Thermostats - Error sending ZWave Command, aborting: 45-2
Mike
