How to Add A Z-wave Interface (controller) to HS3
This topic is closed.
This is a sticky topic.
  • How to Add A Z-wave Interface (controller) to HS3
    This tutorial is on adding a Z-wave controller to HS3. We begin by going to the Plug-ins tab in the navigation and then to the Z-wave option which prompts our last menu. Select Controller Management
    Once that page loads, click the Add Interface button to begin the management process.
    You will then be given the option to name your interface, select the interface model, and pick the corresponding COM port. The interface model will be whichever z-wave controller you have. The COM ports that are actually plugged in will be the only ones that show up in the list.
    Once all of the information is correct, go ahead and click Add
    When initializing, you will get a screen like this:
    Once the z-wave controller has been contacted and initialized, you will need to enable the controller to create the network and complete the adding process.
    Once enabled you should see a screen like this:
    Your network is createed and the Z-troller and HomeSeer are communicating. The actions drop down is where you will perform any actions with your z-wave controller.
    Jon Smith
