HS3 Z-Wave Plug-In Release Notes
This topic is closed.
This is a sticky topic.
  • HS3 Z-Wave Plug-In Release Notes
    Release notes for the HS3 Z-Wave Plug-In
    Changed in version 3.0.2.0 (Release)
    * Prep for HS4 version. All users will need to upgrade to this version before upgrading to the HS4 version of the pluign
    * When the plugin shuts down it updates all Z-Wave data in HS devices as a backup. This data will be used by the HS4 plugin and needs to be up to date
    Changed in version 3.0.1.261 (Beta)
    * Minor fixes for some older Schlage locks
    * Added partial support for the Ring keypad (not complete)
    Changed in version 3.0.1.258 (Beta)
    * Changed device display on HS-FC200+ fan controller to use a slider rather than buttons. This was required for Alexa support.
    Changed in version 3.0.1.255 (Beta)
    * Added fix for root/child association getting lost when Z-Wave plugin starts up
    Changed in version 3.0.1.252 (Release)
    * Added settings for Everspring Siren including new SoundSwitch Command Class
    Changed in version 3.0.1.248 (Release)
    * Added Fibaro FGD-212 EU version to support Scene Activation device as mentioned in previous release
    Changed in version 3.0.1.246 (Release)
    * On the Fibaro FGD-212 Dimmer/Dimmer 2 a Scene Activation device is created for triggering off of button presses. Previous builds had this ability but it was only enabled for the US version. Support has been added for the EU version of this device.
    Changed in version 3.0.1.245 (Release)
    * Changed door locks so it reports different codes for locked by user code and locked by simply pressing the LOCK button on the keypad
    Changed in version 3.0.1.243 (Release)
    * Fixed Kwikset 888 locks now report proper notifications for manual lock/unlock
    Changed in version 3.0.1.242 (Release)
    * Released this version
    * Minor logging changes
    Changed in version 3.0.1.239 (Beta)
    * Fixed some text messages in settings
    Changed in version 3.0.1.237 (Beta)
    * Fixed temp report setting on version 1.3 of HS-LS100+ Leak sensor
    * Fixed Everspring ST814 not reporting
    * Removed "Auto" setting for setting parameters (actual number of bytes needs to be specified)
    Changed in version 3.0.1.227 (Beta)
    * Fixed settings for ramp rates on latest HS-WD100+ Dimmers
    Changed in version 3.0.1.225 (Beta)
    * Cleaned up device names for the HomeSeer Door Sensor
    * When adding HS-DS100 door sensor, only 2 child devices are created, rather than 5. Sensor binary devices are not needed.
    * Fixed "switch reverse" parameter setting for the latest HS-WD100+ dimmer
    Changed in version 3.0.1.224 (Beta)
    * Restoring to a Zee S2 or Z-Net with an updated Z-Wave ZDK 6.81 would fail, this is fixed (invalid function ID 46 error). Restoring to a UZB interface is not supported at this time.
    Changed in version 3.0.1.222 (Beta)
    * Added new Lock Management page from the plugins Z-Wave menu to manage lock PIN codes
    Changed in version 3.0.1.219 (Beta)
    * Renamed central scene values to be consistent
    * Added parameter for HS-WD200+ dimmer firmware 5.11 to change low dim threshold
    Changed in version 3.0.1.218 (Beta)
    * Added support for valve open command with Fibaro Heat Controller
    Changed in version 3.0.1.217 (Beta)
    * Added settings for newer version 50.3 of HS-WD100+ dimmer
    * Fixed some devices not appearing in scene config screen
    * Added "Last" button for dimming devices (device will need to be re-added to system)
    Changed in version 3.0.1.211 (Beta)
    * Fixed Fibaro FGS-223 setting devices to "Unknown" when added securely
    Changed in version 3.0.1.210 (Beta)
    * Add support to restore node info to any Z-Wave interface using Z-Wave SDK 6.71 or 6.81 (includes latest version of UZB and Zee S2)
    Changed in version 3.0.1.208 (Beta)
    * Fixed AEOTEC Home Energy meter not adding properly in secure mode
    Changed in version 3.0.1.207 (Beta)
    * Fixed scene edit page now displays available devices
    Changed in version 3.0.1.206 (Beta)
    * Added support for "Door Open/Close" status for August locks
    * Removed "Ready..." prompt in device settings and firmware update
    * Changed refresh on z-wave controller management screen to 1 second, from 2
    * Fixed firmware update not working with some devices
    * Fixed a crash when initializing z-wave interface
    Changed in version 3.0.1.199 (Beta)
    * WX200 actions, device list, is now sorted
    Changed in version 3.0.1.198 (Beta)
    * Cleaned up some names of the WX200 actions
    * Fixed LED 4 not able to blink when setting ALL devices
    * AEOTEC 4 button controller now includes a device for Central Scene
    Changed in version 3.0.1.195 (Beta)
    * Added another action for the WX200 dimmers/switches to set normal/status mode directly
    * For WX200 devices, less commands are sent when setting status mode LED's to reduce Z-Wave traffic
    * Fixed FGS-222 now responds to S1/S2 push buttons properly
    * Fixes for new JSON interface to manage lock pin codes
    Changed in version 3.0.1.188 (Beta)
    * Fixes for new HS-WX200 switche
    * Fixed Zooz ZEN15 reports status when button is pressed
    * Settings for locks now displays last PIN code that was set for each code location
    * Added API for getting/setting lock PIN codes
    Changed in version 3.0.1.184 (Beta)
    * Fixed events based on Z-Wave notification class commands not triggering if "Do Not Log..." setting in device properties was enabled
    Changed in version 3.0.1.183 (Beta)
    * Added more settings for new HomeSeer products
    * Reduced CPU usage
    Changed in version 3.0.1.179 (Beta)
    * Fixed plugin not always starting up with UZB interface
    Changed in version 3.0.1.173 (Beta)
    * Fixed issue reading some firmware hex files
    Changed in version 3.0.1.164 (Beta)
    * Node information is automatically backed up whenever a node is added or removed from the system
    * Clarified option that changes the node ID so user does not modify this by accident
    Changed in version 3.0.1.160 (Beta)
    * Fixed some issues with updating status when battery devices wake up
    Changed in version 3.0.1.159 (Beta)
    * Fixed Aeon devices that report power not being programmed to report when added
    Changed in version 3.0.1.158 (Beta)
    * Fixed thermostat setpoint commands not being sent for some battery powered thermostats
    Changed in version 3.0.1.155 (Beta)
    * Fixed thermostat set points not being set for some thermostats that are using Celsius mode.
    Changed in version 3.0.1.154 (Beta)
    * Now only one EXE plugin for Linux and Windows
    * Removed support for some older Z-Wave USB HID devices
    * For Fibaro Dimmer2, added a scene activation device so events can be triggered on scene commands sent from dimmers
    Changed in version 3.0.1.152 (Beta)
    * Fixed HS-DS100+, when adding now sets wake-up time to 12 hours, rather than 20 minutes to extend battery life
    * Z-Health has been removed (no longer needed with Z-Wave+)
    * Fixed firmware update slider not expanding
    Changed in version 3.0.1.150 (Beta)
    * Added support for HS3 to trigger on scene activations from other devices, such as the Fibaro Dimmer 2. The HS3 scene activation trigger will trigger on any scene # sent to HS3 even if no device exists in the system that is assigned that scene #.
    Changed in version 3.0.1.148 (Beta)
    * Fixed some Aeotec devices updating the root device rather than the proper switch device
    Changed in version 3.0.1.147 (Beta)
    * Fixed Remotec ZRC-90 now adds properly
    Changed in version 3.0.1.146 (Beta)
    * Fixed issues with Fibaro FGD212
    * Fixed issues with ZUNO and multichannel sketches
    Changed in version 3.0.1.144 (Beta)
    * Fixed assembly reference error on Linux when plugin started (introduced in 3.0.1.143)
    Changed in version 3.0.1.143 (Beta)
    * When controlling multiple devices with the same command, the Z-Wave multicast command was being sent after the individual followup commands, which is incorrect. This has been changed so the multicast is sent first. This results in multiple devices responding in parallel rather than in sequence.
    Changed in version 3.0.1.142 (Beta)
    * Fixed settings now display faster for Aeon Labs G2 modules
    Changed in version 3.0.1.140 (Beta)
    * Fixed Fibaro FGS-212 switches attached to S1/S2 now update status in HS ok
    Changed in version 3.0.1.139 (Beta)
    * Fixed Fibaro FGS-223 switches attached to S1/S2 now update status in HS ok
    Changed in version 3.0.1.136 (Beta)
    * Backed out a change affecting Cooper scene controllers causing LEDs to not sync, awaiting feedback on change
    Changed in version 3.0.1.135 (Beta)
    * Fixed GE switch-sensor, sensor now reports motion, added many settings for this device
    * Updated support for all the latest GE-Jasco devices
    * Fixed routes not displayed in Z-Seer for some third party Z-Wave interfaces
    Changed in version 3.0.1.133 (Beta)
    * Bug fixes to security inclusion process
    Changed in version 3.0.1.130 (Release)
    * Added API support for Z-Seer 3.0.0.40 and later
    * Moved firmware update section in plugin tab to its own section to avoid slow downs entering the properties
    * Changed notification trigger selection for HomeSeer door sensor (and other sensors) to only shows Open and Close options
    * Added icons for Open/Close status for HomeSeer door sensor and other sensors
    Changed in version 3.0.1.128 (Beta)
    * Changes to polling of battery devices to abort poll if device goes to sleep during wake up
    * Disabled setting of polling on all devices other than battery devices (every 12 hours), and older thermostats
    Changed in version 3.0.1.126 (Beta)
    * Fixed some 500 series controllers not reporting last working route
    Changed in version 3.0.1.125 (Beta)
    * Changes to possibly fix excessive delays
    Changed in version 3.0.1.124 (Release)
    * API changes to support Z-Seer+
    Changed in version 3.0.1.112 (Beta)
    * Fixed setting door lock code restarting plugin
    Changed in version 3.0.1.110 (Beta)
    * Fixed issue with adding the Dome motion sensor
    * Added setting to adjust the default timeout for sending Z-Wave commands
    Changed in version 3.0.1.108 (Beta)
    * Added support for the Aeon Labs Wallmote 4 button controller
    Changed in version 3.0.1.103 (Beta)
    * Added support for DOME products (https://shop.homeseer.com/collections/dome)
    Changed in version 3.0.1.102 (Beta)
    * Added support for Notification class version 8 which adds support for more notification types
    * Removed a null z-wave command that was used to keep connections to Z-NETS alive but was causing network traffic
    Changed in version 3.0.1.98 (Beta)
    * Fixed function to remove a bad node, now removes the node properly and deletes the device in HomeSeer
    * Removed wakeup class from HSM200 since it is line powered
    Changed in version 3.0.1.96 (Beta)
    * Setting an indicator (scene controller LED), will not change the actual device status so events will not trigger
    Changed in version 3.0.1.95 (Beta)
    * Added support for GoControl Irrigation Controller
    Changed in version 3.0.1.93 (Release)
    * Fixed error relating to Z-Wave company info
    Changed in version 3.0.1.90 (Beta)
    * Added support for Fortrezz MIMO2
    * Fixed battery reporting not always reporting for battery devices
    Changed in version 3.0.1.87 (Release)
    * Fixed firmware update failing on HSM200
    * Added config settings for EU version of Aeon Labs multisensor
    * HSM200 always returns LUX for light level
    * Fixed wakeup interval setting fro Aeon Labs contact closure sensor
    Changed in version 3.0.1.83 (Release)
    * Added setting for local dimming ramp rate for HomeSeer HS-WD100+ Wall Switch
    Changed in version 3.0.1.80 (Release)
    * Changes related to updating the firmware on the HomeSeer WS.. switches
    Changed in version 3.0.1.76 (Release)
    * Fixed ramp rate timer setting not settable in settings for HomeSeer plugin module
    * Added option to disable all polling on config page
    Changed in version 3.0.1.74 (Release)
    * Added AUX mode for Trane touchscreen thermostat
    Changed in version 3.0.1.72 (Beta)
    * Added support for Fibaro Swipe controller
    * Minor changes to better support some newer Fibaro devices
    * Setting parameters/associations on battery devices now queues setting and sends when device wakes up
    Changed in version 3.0.1.66 (Release)
    * This plugin is required for full of the HomeSeer line of wall switches
    * Added settings for Aeon smartstrip powerstrip
    * Thermostat support for Amazon Echo
    * Minor UI re-wording
    Changed in version 3.0.1.61 (Beta)
    * Fixed some thermostats not being able to set set points (HeatIt for one)
    * Added better support for Aeon SmartSwitch 6 Dimmer and Switch
    * Added support for Aeon window sensor
    * Added some new notifcation types for notification class
    * Fixed an issue where some command responses were not processed
    Changed in version 3.0.1.55 (Beta)
    * Fixed out of memory error when selecting a Z-NET from the controller management page
    Changed in version 3.0.1.53 (Beta)
    * Fixed App version not displaying proper version #
    * Fixed "IL" error when removing a device from the network
    Changed in version 3.0.1.52 (Beta)
    * Fixed Z-Tool+ prompting for name information when removing a device
    Changed in version 3.0.1.50 (Beta)
    * Minor change to allow unknown devices to have status pairs added to them and allow triggering (for devices like the Wayne Dalton garage controller)
    * Added new log option on plugin config page to log device send/receive information to HS log
    Changed in version 3.0.1.48 (Beta)
    * Changed "Button Press" action in controller functions to emulate a binary device, this allows HS to be added to other controllers as a target.
    Changed in version 3.0.1.47 (Beta)
    * Added support for Linear motion sensor and door sensor
    * Added icons for Aeon multicolor bulb (actual icons are in HS3 ver 3.0.0.216)
    * Removed parameter caching as reading parameters was not always reliable
    * Added extra checks to keep Z-Wave interface, such as a Z-NET always connected
    Changed in version 3.0.1.41 (Beta)
    * Added support for NodOn 4 button octan controller
    * Added support for Aeon Gen 5 4 button KeyFob
    * Added support for Aeon Gen 5 Panic Button
    * Added support for Aeon Gen 5 Home Energy Meter
    * Added support for Aeon Gen 5 Contact Closure detector
    * Added support for Aeon Gen 5 Door Bell
    * Fixed Aeon recessed door sensor wake up time for battery updates
    Changed in version 3.0.1.37 (Beta)
    * Added dimming ramp rate settings for GE Jasco dimming wall switch
    * More settings added for Aeon heavy duty switch, Aeon Gen 6 smart switch
    * Fixed Aeon smart strip, now reports power on all 6 sockets
    * Dragon Tech switches now report their status when controlled locally
    * fixes for dimming with Fibaro 2 dimmer
    * Cooper (Eaton) scene controllers now automatically keep LEDS in sync between controllers
    Changes in version 3.0.1.25
    * Added support for Z-Tool+ version 1.2 for advanced diagnostic functions
    * New Z-Wave action to set parameters in a Z-Wave device
    Changes in version 3.0.1.23
    * Added support for Z-Tool+ mobile app
    Changes in version 3.0.1.22
    * Added settings for Fibaro motion sensor with ID of 1001
    Changes in version 3.0.1.20
    * Better support for Netichrome/Qubino dimmers, Fibaror roller shutter
    * Added more settings for Fibaro motion sensor
    Changes in version 3.0.1.17
    * Added settings and better support for Fibaro multisensor
    * Added caching for config parameters, loads settings faster
    * Fixed multiple browser windows causing random status display for Z-Wave functions
    Changes in version 3.0.1.16
    * Fixed network wide inclusion works better for Z-Wave+ devices
    * Added settings for Aeon Gen 5 multisensor
    * Some status images changed to use new icon set file names
    * Removed firmware version check when entering Z-Wave config page if device supports firmware update (loads config page faster)
    Changes in version 3.0.1.11
    * Fixed some energy reporting devices not logging energy usage (Fibaro plug module was one)
    * Fixed Linear garage door module going to "Unknown" when door was opening/closing, it now reports "opening/closing" status
    * Fixed Linear garage door module reporting an error getting barrier class version when adding to the system
    Changes in version 3.0.1.9
    * Fixed some versions of Schlage locks not adding properly
    Changes in version 3.0.1.7
    * Fixed child and root devices being separated when restoring Z-Wave info from HS devices
    Changes in version 3.0.1.6
    * Fixed Zee S2 not able to use Z-Wave and X10 at the same time
    Changes in version 3.0.1.5
    * Fixed node restore for older Z-Troller
    Changes in version 3.0.1.4
    * Added support for upcoming HomeSeer Z-Stick+ controller
    * Added node restore for Z-Wave.Me USB controller
    * This plug-in is now Z-Wave+ Certified!
    * Added option to add a device unsecurely (Use this option to add battery devices that support the secure class, increases battery life 3X)
    * Fixed path to Z-Wave database file when file is moved between Linux and Windows
    Changes in version 3.0.1.0
    * Mainly device class changes for Z-Wave certification
    * Fixed replication to/from a secure controller
    Changes in version 3.0.0.216
    * More command classes added/modified for Z-Wave certification
    * Added "Replace Failed Node" to Z-Wave tab to replace a node and keep the same node ID (required for certification)
    * If you see warnings in the log about command classes, re-install the plugin, the message was from debugging
    Changes in version 3.0.0.214
    * Fixed error restoring network
    * Added support for adding secondary Z-NET controllers (STILL IN TEST)
    Changes in version 3.0.0.213
    * Removing group 3 associations for Fibaro devices should work now
    * Reported dim level when controlling GE Jasco switches should be accurate
    Changes in version 3.0.0.212
    * Fixed 2GIG CT100 humidity now reports properly
    * Associations can now be removed from device using the settings
    * Backend changes for certification
    Changes in version 3.0.0.210
    * Minor UI changes
    * Fixed Enerwave motion sensor, now detects motion properly (device will need to be re-added)
    * If you have a HomeTroller Zee and would like to test this plugin, ssh to your Zee and manually update to build 155 (see the Zee forum for manual update instructions using SSH)
    Changes in version 3.0.0.209
    * Moved plugin to general Z-Wave Beta
    * Added route speed to "last working route" display on node page
    * Fixed some formatting issues on node page
    Changes in version 3.0.0.208 for Z-NET
    * Some security fixes so more security devices may now add properly
    * Added ability to assign routes to nodes (Experimental!)
    Changes in version 3.0.0.205 for Z-NET
    * fixes to add/remove node
    Changes in version 3.0.0.189:
    * Added fix for adding Linear garage door controller
    Changes in version 3.0.0.188:
    * Added support for ECONET floor vent
    Changes in version 3.0.0.187:
    * Fixed plugin no longer attempts to set a wake up interval on the HSM200 sensor since the sensor does not support wake up.
    Changes in version 3.0.0.186:
    * Fixed random Z-Wave send errors caused by an unresponsive node locking up the Z-Wave controller
    Changes in version 3.0.0.184:
    * Minor timing changes for access to Z-Wave interface
    * Fixed bug 1953 where events would not trigger on a device being set to a value
    Changes in version 3.0.0.182:
    * Added settings for the HSM200 multisensor, this includes settings for the Off delay, light level and temperature reporting interval
    * Added fix for some replication errors
