Is there a way to configure the second switch input of a Fibaro switch or dimmer module to control a virtual device in a similar way one would associate the second input with another z-wave device?
I've had a look but I don't seen to have the option to associate the control with a virtual device.
What I'm looking to do is have a single 2-way momentary wall switch control lighting and audio by installing a Fibaro dimmer behind a double wall switch and use the switch inputs as follows:
1. Control the fibaro dimmer (room lighting)
2. Control a virtual device which will then be used to trigger events for audio control (speakers on/off or play/pause)
I'm sure there are alternative ways of doing this but I'm trying to minimise wall clutter.
