Anyone installed a microdimmer in a lamp? I can't get the level of local control I'd like using lamp modules. I'm thinking of installing a micro dimmer on a lamp,, adding a momentary push button somewhere on the lamp and then disabling the lamp's socket switch by either removing the knob or replacing the socket with a non-switched socket. Anyone tried this?
Aeon Labs Micro Dimmer in a lamp
John
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3Tags: None
After talking with Aeotech I went ahead and tried this. I used these switches: http://amazon.com/dp/B00T6I8TTG wired to the switch terminals and replaces the lamp holder with an un-switched holder. It works perfectly the lamp stays perfectly in synch with HS and my Cooper scene controllers. The push button switch mounted in the body of the lamp looks like it's always been there. No more having to choose between local or remote control.
Sent from my LGLS660 using TapatalkJohn
