I read that the Schlage Camelot can be programmed from z-wave providers. Does this ability already exist via plug-in for HS3?
Can someone provide an example of how a script sends data to the devices to set values?
Such as, in vb after a reference to a device is established, what function is used to set values on the device?
Camelot access codes are programmed by locking the door, entering the programmer's code # then '1' then entering the new access code # twice.
How is this string sent to the device via script?
