Based on experiences what's the recommended implementation in HS3 for tracking and reporting room presence / occupancy, including duration of time in each room?
I have two types of motion sensors in key rooms, z-wave and DSC-alarm wired, that can be used with HS3 virtual devices and timers. Since motion sensors only report motion in set time intervals this may complicate the above objective and create inaccurate tracking and report results.
Does anyone have something like this and is it working well for you? If so, can you provide details on how you have this set up?
Example use case: You put your home in vacation mode (virtual device), which specific HS events will use. A business or someone you know is caring for your home and/or pets while you are away in vacation mode. You want to monitor and report the interior rooms they are going into and how much time is spent in these rooms.
