Hi,
For several months there is an issue with the Fibaro and Qubino double Z-Wave switches. I only use the Plus versions, but I believe the same issue exist in the non-Plus versions. Unfortunately, version 3.0.1.74 does not fix this (the release notes mentions a fix for Fibaro switches).
The problem is best decribed here: http://forums.homeseer.com/showthread.php?t=179370. Here is the important part from that thread:
S1 - Binary Switch for Main Lights
S2 - Binary Switch for Wall Lights
When I operate S1 from HomeSeer; the main lights operate, and S1 indicates ON. Great
When I operate S2 from HomeSeer; the wall lights operate, and S2 indicated ON. Great
When I operate S2 from the normal light button (standard button); the wall lights turn on, and S2 indicated ON. Great
Here's the problem: When I operate S1 from the normal light button (standard button); the main lights turn on. Good up to now but HomeSeer displays S2 as ON ???
Note that not only the incorrect HS3 device is indicated, but also the power reporting is going to the incorrect HS3 device.
Thanks for looking into this!
