Hi all. I have an UZB zwave.me stick that, when it works, works fine.
I can see the blue led that quickly flashes when I send a command to a device and the device moves the shutters (Qubino Flush Shutter).
The problem starts when, for some reason, the command is not handled/received from the destination device, the led on the UZB remains turned on for more the 50 seconds (53 exactly), during this time I can't send any new command until the led turned off...so it stuck for about 1 minute!
The same thing happens when trying to fully optimize the network, at the first device that cannot be reached the UZB hangs with the blue led on and so the next devices cannot be optimized until 1 minute is passed.
I tried a full optimization of the network for more than 4 times, optimizing node by node, setting the routes manually.....sometimes it works (very fast), sometimes it hangs for 1 minute (command not received by the device because the shutters doesn't move).
I have noticed that the UZB (primary controller) has a large list of neighbors including nodes that are currently turned off. So the full optimization....optimizes the nodes but not the neighbours of the primary controller? May this be related to the problem or is it an UZB/HS problem? How can I remove the "ghost" neighbors in the primary controller?
Any hints are apreciated.
Thanks.
Thanks.
