Schlage Zwave error
    Schlage Zwave error
    Just installed a new Schlage Connect over the weekend. Have received this warning message today after a unlock event. Have seen this twice so far in the handful of times unlocking with user codes. Lock is a BE469.
    Sep-26 3:44:53 PM Z-Wave Device: Node 45 Z-Wave Access Control Notification Set to NOTIFICATION for type Access Control Notification, Event: Auto Lock Locked Operation
    Sep-26 3:44:53 PM Z-Wave Warning Z-Stick : Secure message received from node 45 but the data length is too short. (Not Processed)
    Sep-26 3:44:24 PM email Email successfully sent to xxxxxxxxxx@mms.att.net;xxxxxxxxxx@mms.att.net
    Sep-26 3:44:23 PM Event Event Trigger "Door Lock FrontDoorOpenKids"
    Sep-26 3:44:23 PM Z-Wave Device: Node 45 Z-Wave Access Control Notification Set to NOTIFICATION for type Access Control Notification, Event: Keypad Unlock Operation
    Node 45 info:
    Manufacturer:
    Ingersoll Rand Security & Safety Type: 0x6341 ID:0x5044 Listens:Yes (Beam 1000ms) Version: 3.42 (ZDK 4.54.1) Firmware: 113.22 Neighbor Count:21 Speed:40Kbps
    I've found unless the lock can directly communicate with the interface (Z-NET etc) these types of errors are common.
      Same here. Even devices that are supposed to repeat security packets, such as the Aeon Labs ZW080 sirens, do not seem to help this.
        Schlage Zwave error
        Any way to fix this. There is an Evolve Light switch next to the door and a GE outlet with in 5 feet of the door. Many other GE outlets and a few Evolve and one new HS light fairly close
        Using a usb Zstick.
        Optimization results in Delete current return route failed. Add return not attempted. ~40 devices total.
