I haven't been able to find much information on the zigbee plug-in. I am wondering if there is a list of devices somewhere that can be used with this plug-in. I have the sylvania smart+ (osram lightify) hub and a bulb and they work fine. Just need to know what else will work! thanks
What can we use with this plug-in?
Originally posted by cowinger View PostDoes anyone know if this plug-in will work with all zigbee devices or is it limited? Anyone!
Elliott
Originally posted by Richel View PostI think it may be limited to Osram Lightify. I am using it with their bulbs and their gateway. It works well, but only for brightness and color temperature, not color.
Elliott
Originally posted by macromark View Post
Does that include:
We know Sylvania & Osram
GE?
TP-Link?
Sengled?
How do we know for sure if these are all compatible?
Found this website:
http://www.zigbee.org/zigbee-for-dev...ee-light-link/
It shows Zigbee Light Link, including GE, Greenwave, OSRAM Sylvania and Philips.
The Zigbee devices that can be seen are relating to the firmware on the OSRAM LIGHTIFY Wireless Gateway.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X - HSTouch on Intel tabletop tablets
HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
HS4 Lite -X10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
Originally posted by Pete View PostThe Zigbee devices that can be seen are relating to the firmware on the OSRAM LIGHTIFY Wireless Gateway.
Elliott
How does the "Light Link" play a part in all of this. Osram says they are compatible with it and the brands I mentioned all claim to use it.
Light Link is just Osram's proprietary name for their Zigbee protocal. Compatible brands work with the Osram Light Link Zigbee hub firmware.
Such that whatever is on Osram's list mentioned by cowinger will work. The Osram hub is the most cost reasonable at $28.00.
Same or similar to the use of the above Zigbee JowiHue paid pluging working with the RaspBee. IE: you can now do a ZNet like Zigbee thingamajig. IE: a Zigbee GPIO card on a RPi connected via a POE connection in the attic. Only difference is that it is not a cloud connected hub and will cost more than $50 with an RPi and GPIO Zigbee card.
My Zigbee Leviton serial ZIM has a tiny LCD display and allows connectivity to Zigbee appliance / light modules, thermostats and door locks. Not sure if it works with light bulbs. Thinking I paid less than $200 for the ZIM.
The Smarthings cloud connected hub talks ZWave and Zigbee. Paid less than $100 for the Smarthings hub. (well it was a gift - so it was free).
The Almond + talks ZWave,Zigbee and regular wireless and can be used as a cloud connected hub or not. Less than $200.- Pete
Originally posted by Pete View PostHow does the "Light Link" play a part in all of this. Osram says they are compatible with it and the brands I mentioned all claim to use it.
