Exception retrieving the authorization token
  • Jobee
    @Rich
    Any update on a fix yet?
  • gaf@bluerivernet.com
    Zigbee Plugin Down
    How much longer is the Zigbee community going to have to wait for a fix? This is rediculous!
    GAF
  • Rupp
    This is a known issue and support is working on a fix.
    There was an exception retreiving the authorization token
    Me too. both on existing lab set up and at new S6 in my home under construction....Need help as well.
    GAF
  • cowinger
    You can add me to the list. I see proadmin put in a ticket, anyone else? I had a osram hub from a while back and decided to play around with it again. After I went through their app setup it showed the same as what proadmin is seeing. "Test was not successful"
    Any word from admin?
  • Rupp
    Put in a support ticket if you are experiencing this issue. Email support@homeseer.com
  • drmcp
    any updates
    i am seeing the same no zigbee working
  • Guest's Avatar
    Guest replied
    Same issue
    Any news on this i am having the same issue.
  • jnarva@cobaltsphere.com
    Fix in the Works for Zigbee Gateway
    I logged a support ticket on Sunday, here's the response I received from support today.
    "We found the problem and will have an update out as soon as possible. We will update you when we have more information."
    So I'm guessing they have a solution and all they need to do is final code, review, package test and push.
    Really miss having this interface, it's used every day in our house.
    I really wish they had a Zigbee solution that was controlled locally (USB gateway) and didn't rely on another vendors API.
  • proadmin
    I have a support ticket open. We'll see what they come back with. I suspect OSRAM has changed their API. It concerns me more than a little that we're the only ones that seem to be complaining. Do that few users use the ZigBee integration?
  • proadmin
    Seeing same error - no ZigBee control via HomeSeer
    I'm seeing the same error. Just started within the past few days. This install has been working fine for over a year. Using the OSRAM Lightify Gateway. No control from HomeSeer, but Lightify app still works fine.
    Testing Cloud Connection in plugin reports "Test was not successful". I've updated Lightify gateway, HomeSeer and even reset password in Lighify. No joy.
  • slbuck
    started a topic Exception retrieving the authorization token
    Started getting the following error recently in homeseer. I can control the lights via the android app via the cloud with no problems.
    Anyone else seeing this?
    Apr-05 21:20:27 ZigBee Error: There was an exception retreiving the authorization token
    The osram lightly gateway just recently updated.
    Gateway Wi-Fi version: 1.2.9.0
    Gateway zigbee version: 1.2.0.68
    Current Date/Time: 4/5/2018 9:17:08 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.368
    System Uptime: 8 Days 19 Hours 38 Minutes 49 Seconds
    IP Address: my
    Number of Devices: 616
    Number of Events: 530
    Available Threads: 400
    Enabled Plug-Ins
    3.0.0.44: EasyTrigger
    3.0.0.29: EnvisaLinkAdemco
    1.2.1.0: Honeywell WiFi Thermostat
    3.0.0.6: HSZigBee
    3.0.0.14: NetCAM
    2.1.6.0: OpenSprinkler
    3.0.1.114: PHLocation
    3.1.0.22: Sonos
    3.0.6647.37642: UltraLighting3
    3.0.0.83: weatherXML
    3.0.1.208: Z-Wave
