Lightify Problems
    #16
    Originally posted by cowinger View Post
    Sounds good. Resetting these bulbs can be tricky. I don't know if you found the procedure for this but I will throw it in just in case.
    1. start with off
    2. on for 5 sec
    3. off for 5 sec
    repeat this 5 times and on the 6th 'on' just leave it on. It should blink 3 times if it is a white bulb and 3 colors if a color bulb. It takes a few seconds for it to do it.
    Well, this did not make a difference. Only one device for brightness gets created. I think it is a bug in the HS Zigbee plugin.
    Elliott
    "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
      #17
      Elliott
      I wondered if the plugin was fixed for the newer bulbs. Have you considered using the conbee and the jowihue plugin. There are a lot more devices you can control with this plugin. Osram for sure and you get all the child devices. It is not that hard to set up. There is a lot of people here that can help you with setting it up. A small extra cost but not bad. Just a thought.
        #18
        Thanks for the great suggestion. I will order one.
        Elliott
          #19
          Elliott
          Once you have your conbee here is a little help on getting things going. Hope it helps.
            #20
            Thank you so much!
            Elliott
              #21
              Thank you so much!
              Elliott
              You are quite welcome. Let us know how it goes!
                #22
                I will!
                  #23
                  My goodness, even with your excellent instructions, without which I would have been lost, it was not an easy installation. Nonetheless, I have gotten everything up and running. Thank you, again.
                  Elliott
                    #24
                    Elliott
                    Your welcome. Glad to see you have it all working.
