OK, I got Zigbee, what do I do now?
  • OK, I got Zigbee, what do I do now?
    I recently got a Yale digital lock for my front door, with a networking module. They told me the module works with Zigbee. So I got an Amazon Echo Plus, which has a Zigbee controller built in. I have managed to get it working so that Alexa locks (and UNLOCKS! Yes, it can be done!) the front door.
    So now I would like to see the front door lock in HomeSeer. So I downloaded the HSZigbee plug-in. From that point, I am totally lost, I know nothing about Zigbee. It says I have to go to something called OSRAM LIGHTIFY? And get a "token"? So I go there, and it asks me to login. Not register, just login. I don't have a login for OSRAM. Reading the sticky here, I see there was some trouble with the OSRAM interface? But that was solved, right? So where do I go from here?
    Jim Speiser
    30-year veteran of Home Automation
    Still don't know squat
    I don't think you can use the ZigBee in the Echo plus with HomeSeer. You might need a ZigBee interface for HomeSeer.
      ZigBee is still a long wanted capability with HomeSeer. You can't do anything with devices attached to an Echo Plus....nobody can except Amazon at this point.
      The HSZigbee is only good for Osram/Lightify lights and plugs nothing else. JowieHue integrates with deCONZ which is good but you are still limited to what deCONZ supports which is again mostly lights and some plugs and xiaomi sensors.
        Yale is not yet on the Supported Devices list for Zigbee2MQTT, but likely only because nobody has had one to try. The forum https://koenkk.github.io/zigbee2mqtt/ is very active and I have found the developer to be very responsive for the new devices that I am adding. To try this you need a $10 Zigbee USB dongle, A Linux or Windows computer to run the Zigbee2MQTT and MQTT broker programs in the background and free mcsMQTT HS plugin.
        If you want this dongle then provide your shipping address to mcsSolutions at CenturyTel dot net. The documentation at the link above tells you how to install and run zigbee2mqtt. If you prefer windows then the install is described at https://forums.homeseer.com/forum/li...qtt-on-windows
          I have not played with this yet, but I'm game. I sent you the email with shipping info... another Zigbee dongle to add to my collection
            Belated thanks to all for your replies. I understand that basically I cannot control the Yale lock through HS3. No biggie, Alexa works fine with it.
            Thanks again and Merry Christmas.
            Jim Speiser
