Can you use the Lutron Aurora as a lightswitch with Homeseer?
  • Lucid
    Since nobody has responded yet, another workaround I'm curious about (if all else fails), is that perhaps using this with a Hue hub will send the correct information to Homeseer, and then Homeseer can send it along to the Lifx bulbs. It's an expensive and sloppy solution, but perhaps it will work (if it's not too laggy, of course).
  • Lucid
    started a topic Can you use the Lutron Aurora as a lightswitch with Homeseer?
    So this product is easily one the best light switches I've ever seen for smart lights, but by default it only works for Hue brand lights... the problem is hue lights are very dim (800 lumens max for color bulbs), and Lifx carries some robust 1100-1200 lumen bulbs.
    So can this Zigbee 3.0 product be tied into Homeseer to let me control lights I have connected to Homeseer? My goal is to have them control Lifx bulbs, which should work in tandem with the Lifx plugin for Homeseer.
    Lutron Aurora: https://www.amazon.com/Lutron-Aurora.../dp/B07RJ14FBS
