3.0.1.5 installed. Color updates correctly during poll.
I'm noticing that if I uncheck the "Do not update device last change time
if device value does not change:" option for each of the devices (on/off/dim and color), I'm still seeing the last change time getting updated every poll cycle. Is there a way that you can check to see if that option is enabled for the device before updating the last change time when doing the poll?
HSZigbee Now In Beta
This is a sticky topic.
Originally posted by Sgt. Shultz View PostOnce I push out a new version for color update when polling, I will reset my account and try recreating it for Europe to test with.
Originally posted by Sgt. Shultz View PostCan you send me the JSON you get when you discover your Zigbee devices?
{"devices":[{"id":"201392239","type":"GATEWAY","online":true,"deviceMode l":"LightifyHub"},{"id":"201392239-d01","name":"Desk Lamp","type":"LIGHT","online":true,"onOff":"off","brightness ":100,"colorTemperature":2702,"colorRGBW":{"red":255,"green" :255,"blue":255,"white":255},"colorHSV":{"hue":0,"saturation ":0,"brightness":1},"mode":"colorTemperature","deviceModel": "Classic A60 RGBW","firmwareVersion":"01020510"},{"id":"201392239-d02","name":"Office Light","type":"LIGHT","online":true,"onOff":"off","brightnes s":100,"colorTemperature":2702,"colorRGBW":{"red":255,"green ":255,"blue":255,"white":255},"colorHSV":{"hue":0,"saturatio n":0,"brightness":1},"mode":"colorTemperature","deviceModel" :"Classic A60 RGBW","firmwareVersion":"01020510"},{"id":"201392239-d03","name":"Sharons Lamp","type":"LIGHT","online":true,"onOff":"on","brightness" :100,"colorTemperature":2700,"colorRGBW":{"red":255,"green": 255,"blue":255,"white":255},"colorHSV":{"hue":0,"saturation" :0,"brightness":1},"mode":"colorTemperature","deviceModel":" Classic A60 RGBW","firmwareVersion":"01020510"},{"id":"201392239-d04","name":"Deans Lamp","type":"LIGHT","online":true,"onOff":"off","brightness ":10,"colorTemperature":2702,"mode":"undefined","deviceModel ":"Classic B40 TW - LIGHTIFY","firmwareVersion":"01020510"}]}
i have the 3.0.1.4 installed and i have authenticated and retrieved my token and have created the devices which detect correctly.
but that's it, i cannot control the lights, when attempting to control the lights i get the following log entry after a about 5-6 seconds
Command returned an error: The remote server returned an error: (403) Forbidden.
I have the Debuggin tickbox checked and allthough it shows the response from the server listing the JSON of all my lights, it does not change when i try to control the lights.
I do have Europe selected in the dropdown
any help would be appreciated
Originally posted by Sgt. Shultz View PostIt sure should.
The .ini file for the plugin is in the config folder.
It's called zigbee.ini
It can be opened in notepad.
Change the country from us to na.
It's not setting it because it already has a value.
I've updated the plugin with code to check for this.
New version is 3.0.1.4
When I checked the zigbee.ini file, the country still shows as "Country=us" rather than being updated to "na" since that is what server is selected.
Since Lightify has a North America and Europe server, would it make more sense to change this from Country to Server in the ini file?
It sure should.
have 3.0.1.3 installed and still an issue here.
Here is the event log from HS3:
Code:May-15 14:03:12 ZigBee Error: There was an exception in the 'Send' function: Invalid JSON primitive: The. May-15 14:02:48 Starting Plug-In Plugin HSZigBee started successfully in 27 milliseconds May-15 14:02:48 Starting Plug-In Initializing plugin HSZigBee ... May-15 14:02:48 Info Plugin HSZigBee has connected. IP:127.0.0.1:58596 May-15 14:02:47 Plug-In Finished initializing plug-in HSZigBee May-15 14:02:38 Updater Install/Update of package HomeSeer ZigBee was successful. May-15 14:02:38 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\HSPI_ZIGBEE.exe May-15 14:02:38 Updater Installing package HomeSeer ZigBee May-15 14:02:38 Updater Update HSPI_ZIGBEE.exe downloaded successfully May-15 14:02:38 Updater Downloading update: HomeSeer ZigBee May-15 14:02:38 Updater Starting download of updates
Code:Debug Response: The remote name could not be resolved: 'us.lightify-api.com'
My bad.
In my haste, I missed putting the new EU client ID in the link.
This is the correct one:
https://emea.lightify-api.com/oauth2...onse_type=code
I will update the plugin and push it out in a minute.
Help?
Hi
New to Homeseer, last system was Zipato and want to connect it to my Osram devices. Not shure what to do with the plugin and token. Getting this page when i click tle link in the setup:https://myhs.homeseer.com/lightify/t...%20not%20exist
So here's where we are...
Lightify finally managed to get me an account on the european servers, so I could create a client ID and secret for it, so the Lightify plugin should work now.
I haven't tested it yet..., if there's an issue, once I get through with the NA server I'll redo my Lightify account for Europe and look at it.
It also looks like Lightify is putting different properties onto their products that aren't in the standard schema they are providing, and they haven't gotten back to me regarding any JSON that might be different.
For those people having an issue with the discovery process, I have put a debug area on the config page to show the response from Lightify for a request.
That will allow me to see what you see by having you copy and send it to me.
Then I can adjust the object receiving the post from Lightify, and maybe even add some additional functionality based upon it.
As a note, I would not have polling enabled when you use the debug, as the response area gets overwritten as a new response comes in.
The account for the NA servers is finalized and shouldn't need to be touched again, but if/when you download the new plugin, the client ID will be new so it won't automatically refresh your tokens(they expire after two weeks)
That means you will need to remove the current zigbee devices and get a new token and refresh token through the config page.
Having some issues getting a developer account set up for that, working on it though.
Originally posted by fuzzysb View PostAny news on the EU version. According to the API it requires 0 changes other than the URL. So as you already have the selection this should be easy to implement.
I just don't this losing focus as it's really important to my setup
Sent from my SM-G950F using Tapatalk
