Contacting HomeSeer This Week
See more
See less
After Update Plugin is Gone.
  • #16
    Originally posted by MattL0 View Post
    Did the repair process
    Matt, what's the "repair process"?
    • #17
      sorry I meant to pair the plugin with the google account
      • #18
        I actually had some problem with Google account too, I suspect it wasn't the plugin - could be a temporary Google issue.
        • #19
          Yeah:
          https://www.google.com/appsstatus#hl...ae2b52e3dde98f
          • #20
            That explain it!. Will put this link in my bookmarks! Thanks
            • #21
              • #22
                I have enabled dev mode and I get no console window on startup of plugin?
                I'm going to restart HS3 again...also your plugins still don't stop when I disable them in HS3...I have to manually kill the process in Windows.
                So it appears I had to install the .NET 4.7.2 runtime, even though my Windows 2016 server has all the latest patches; did you update your modules to use the newer version?
                • #23
                  Yeah, I updated to 4.7.2 - but it should be compatible with 4.6.1 I was using before. May be you had an older version?
                  So, after updating .NET - do you still have issues?
                  Before restarting HS3 - disable dev mode. When you say - "get no console window on startup of plugin" - that's almost impossible. If it's the case you need help from HS support.
                  • #24
                    Many users when they have a problem - they start trying many things including even reinstalling HS completely. Have to admit - guilty myself (tied reinstalling HS once). Main reason been probably - no trust in HS support and luck of plugin developer support... But quite often problem is simple - and using "Developers mode" is the best troubleshooting (in my opinion).
                    Often problems are related to .NET Assembly resolving issues - and there are tools for trouble hooting these. On Windows there's a Fuslogvw.exe (Assembly Binding Log Viewer) , on Mono there's an option to enable assembly load tracing.
                    • #25
                      Maybe a virus scanner being overly aggressive and quarantining the file?
                      • #26
                        Yeah, that happened to me - with Jon00 plugin
                        • #27
                          Nope, 2016 with the latest patches...I update everytime MS has an update. After enabling dev mode in HS3, the console window indicated I needed to install 4.7.2; I already had the latest version that MS installs for 2016. All is working now...
                          • #28
                            Originally posted by MrMxyzptlk View Post
                            Nope, 2016 with the latest patches...I update everytime MS has an update..
                            I don't think .NET runtime is included in Windows updates
