Not set to an instance errors
    Hi Alex
    I am getting these errors on the plug in page. "not set to an instance" Here are a couple screen shots.
    Originally posted by Meapilot View Post
    Hi Alex
    Anything in the logs?
    Also, please enable the "Developer Mode" on Plugins -> Manage page and restart the plugin. The plugin should start with console window where you can see more output. Assuming you are on Windows?
      Console copy with Developer Mode enabled.
      *** I have no idea what did it or why. I did restart multiple times the plug in as well as HS3. It seems to be back to normal now
      Thanks anyways!
        Yeah, nothing wrong in the logs. Glad it works.
          Good all looks well. Weird, but still seems to be fine.
          Thanks for having a look!
            Could be some network issue
              Not sure if this is a configuration problem or bug on my system - The Google Home and Chromecast devices do not show this message.
              I get this error on my SonyTV Chromecast. It has a Triangle with with Exclamation mark in it. The Hover text is "Connecting to HSgSpeakHost: object reference not set to an instance in an object"
              Does this mean the TV is not capable of being used as a "Speaker"? Does this functionality need to be disabled for some devices?
Name:	Triangle on SonyTV Chromecast.jpg
                Does it happen all the time? Or sometimes it works? Anything in logs?
                  I have Samsung TV with built-in chromecast, but it's not reliable - so I had to buy proper Google Chromecast and it works fine...
                    I didn't see anything in the log. I just toggled the PI again - (I have done this several times prior to today, and the triangle always came back)
                    No triangle now. Go figure
                    Solved (for now?) (BTW using V 3.0.0.41, I'll try 3.0.0.42)
                      This triangle appears if there's an error. Possibly sometimes you get the comms error - then it appears. I created this feature to make errors more obvious - not just logged.
                      Normally if comms is restored - the triangle should be cleared. Definitely it's cleared on plugin restart. I need to check my source code.
                      But if it works - generally you can ignore the warning.
