Linux errors HS3
    Linux errors HS3
    I just went back to your plug-in from the 'other' after issues with a rogue unit.
    running 3.0.078 my log is flooded with these errors:
    Nov-04 1:42:44 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-04 1:42:36 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-04 1:42:32 PM Warning Plugin AK GoogleCast is not responding but it is still running, not restarting yet.
    Nov-04 1:42:29 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-04 1:42:23 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-04 1:42:22 PM AK GoogleCast Warning Zeroconf (mDNS) discovery is disabled
    Nov-04 1:42:22 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    Nov-04 1:42:21 PM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
    I am stumped. It 'appears' to be working, but I don't want to dedicate too much time switching everything over if it is failing.
    I saw before issues with the discovery so I let it discover then I disabled the discovery option and restarted the plugin and then HS3.
    But it still fails.
    ideas? help?
    It looks like the errors are on the config page, not the plugin itself. Can you please confirm when the errors happen, what are you doing?
    What's you Mono version?
      Looks like it is due to the fact that I tested this plugin months ago and my Google config has changed and there were 2 groups in the plugin that I did not have in Google.
      I manually edited the config file and deleted the offending lines.
      It seems to be all good now.
      thanks!
      Scott
        and thanks for the quick response - I knew there was a reason to switch over 👍
          Thank you
            I am still running into issues:
            Nov-13 9:27:09 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:27:02 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:26:55 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:26:48 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:26:46 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:25:59 AM AK GoogleCast Speakers: BONUS, KEEGAN, MASTER BEDROOM, OFFICE, FAMILY ROOM, LIVING ROOM, GARAGE, MBIPAD2, KITCHEN, KITCHENIPAD
            Nov-13 9:25:58 AM Speaker Speaker host added, Name: GOOGLECAST Instance: Master Bedroom IP address: 192.168.1.195
            Nov-13 9:25:55 AM Error Calling HSEvent in plugin AK GoogleCast, Instance :Object reference not set to an instance of an object
            Nov-13 9:25:45 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:25:43 AM Error Posting back to plugin web page AKGoogleCast_Config_Page: Object reference not set to an instance of an object-> at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00108] in <9f0df102fe6e4cfea29d2e46f585d8a5>:0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.PostBackProc(string,string,string,int ) at Scheduler.proxyPage.postBackProc (Scheduler.StateObject& state, System.String Data) [0x00036] in <7559e587c425419191158a614d9e22a2>:0
            Nov-13 9:25:24 AM AK GoogleCast Speakers: BONUS, KEEGAN, OFFICE, FAMILY ROOM, LIVING ROOM, GARAGE, MBIPAD2, KITCHEN, KITCHENIPAD
            Nov-13 9:25:22 AM AK GoogleCast Warning Found Receiver [Google Cast Group] Common Area (192.168.1.80:32193): groups are disabled!
            I am getting these and they plug-in page for HS3 says the plug-in is loaded remotely, and I cannot control it. the only way out is a restart of hs3
            I have run into this a few times already since installing.
            I tried disabling the groups to see if that would help, and this happened.
              It looks like the error is on the config page? Can you try to identify when exactly it happens? When you click "Use groups" checkbox?
                I tested 3.0.0.79 on Ubuntu 20.04 - works fine
