Tried to install today, but no dice...
  • Tried to install today, but no dice...
    The download and installation seemed to go without a hitch, but when HS3 comes up, I get the following:
    WARNING: Failed getting InterfaceStatus from BLiTunes - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    I am running W10Pro with the latest updates.
    I am running THE LATEST iTunes.
    I am running the latest HS3.
    Any ideas?
    Same with BLMediaPlayer...
    Tried BLMediaPlayer for grins and Got the same error.
    WARNING: Failed getting InterfaceStatus from BLMediaPlayer - the interface was not found in the list of active interfaces, the list may need to be refreshed.
      Can you turn on debug logging
      1. Disable the plugin
      2. Edit the hspi_BLiTunes.ini and change debugLevel=true
      3. Save INI file
      4. Re-enable the plugin
      Once you get the issue then turn off debug logging and attach the BLiTunes-Detailed.log file zipped
      It is in the HS3 root folder
      Cheers,
      Bob
