Description
This topic is closed.
This is a sticky topic.
  • Description
    The BLiTunes Plug-in for HomeSeer allows the user to interface with iTunes. This plugin is written in VB .Net 2.0 and requires HomeSeer Version 2.1.0 or later.
    • Allows iTunes control from plug-in.
    • View iTunes playlists.
    • Allows user to specify starting volume level for the player.
    • Allows the user to specify the action to take when HomeSeer is speaking: No Action, Pause, Mute, Preset Volume then Ramp Back Up
    • Users can setup HomeSeer events and use BLiTunes actions to control the player.
    • Users can setup HomeSeer events that trigger on BLiTunes triggers (eg: Playback Started, Playback Stopped, etc)
    • Allows user to toggle shuffle play and repeat play.
    • Users can quickly select an artist, album, genre or playlist to play.
    • Allows user to send current media information to all Message Server Plug-In clients (NOTE: Message Server Plug-in must be installed)
    • Allows user to send current media information to all BLBroadcast Plug-In clients (NOTE: BLBroadcast Plug-in must be installed)
    • User can setup the maximum number of minutes that the player can be paused before the player is stopped.
    • Dim volume control processing enabled for use with stick-a-switches and palm pads.
    Cheers,
    Bob
